Modern Glues Are Amazing
« back to Joinery forum
Forum topic by CharlieM1958 posted 08-16-2015 10:04 PM 1181 views 1 time favorited 17 replies Add to Favorites Watch
16272 posts in 4120 days
08-16-2015 10:04 PM
I laminated some 1/8” thick sycamore to some 3/8” walnut for a box I’m working on, using good old Titebond II. In the course of cutting pieces to size, I sliced this off on the table saw. I was blown away that even on this paper-thin shaving, the sycamore would not separate from the walnut. Even when I tried, the walnut or the sycamore would split while the seam remained intact.
17 replies so far
View grizzman's profile
grizzman
7836 posts in 3205 days
#1 posted 08-16-2015 11:33 PM
yep, your right charlie, ive done plenty of glue ups and the wood will give before the seam, i imagine there is glue out there that we dont have ,except for on a commercial use that would put our glues to shame, i would like to find a test of where they have tried new glues to hide glues…
-- GRIZZMAN ...[''''']
View PurpLev's profile
PurpLev
8534 posts in 3550 days
#2 posted 08-17-2015 12:28 AM
Obviously… You need a better table saw
#3 posted 08-17-2015 12:34 AM
Sharon, it wasn’t easy setting the fence that close to the blade. :-)
View Pezking7p's profile
Pezking7p
3217 posts in 1553 days
#4 posted 08-17-2015 12:37 AM
Pretty cool, eh? No on can blame their glue for weak joints.
-- -Dan
View jeffswildwood's profile
jeffswildwood
2808 posts in 1879 days
#5 posted 08-17-2015 12:47 AM
I use titebond II exclusively. Love it! But I have always wondered what the difference is between titebond I, II, and III. Anyone?
-- We all make mistakes, the trick is to fix it in a way that says "I meant to do that".
#6 posted 08-17-2015 01:06 AM
Basically, it is the level of water resistance. I is strictly for dry applications, II is water resistant, and III is supposed to hold up under outdoor use.
View Daruc's profile
Daruc
460 posts in 1034 days
#7 posted 08-17-2015 03:03 AM
Sharon, it wasn t easy setting the fence that close to the blade. :-)
- CharlieM1958
I would like to see your push stick for that…. :-)
View ajosephg's profile
ajosephg
1880 posts in 3463 days
#8 posted 08-17-2015 03:14 AM
I don’t even consider any other glue
-- Joe
PurpLev
#9 posted 08-18-2015 01:58 AM
- CharlieM1958
- woodust
That WAS the push stick…
View shipwright's profile
shipwright
7893 posts in 2699 days
#10 posted 08-18-2015 02:13 AM
Wood glues have been amazing for a very long time.
I have no doubt at all that hot (or liquid) hide glue would render the same result.
..... not trying to start an argument but if HHG weren’t able to get the job done it wouldn’t be my go-to glue.
View distrbd's profile
distrbd
2252 posts in 2348 days
#11 posted 08-18-2015 02:18 AM
I have not tried titebond II yet, it’s good to know it is as reliable as TB-I and TB-III, I have always used TB 3 for all my glue ups but have a spare bottle of TB I in case a shorter open time is needed.
-- Ken from Ontario, Canada
#12 posted 08-18-2015 02:22 AM
Paul, you are right, of course. My point was not really to extol the virtues of Titebond over more traditional glues (although I admit that is how it sounded). I was just pretty darned amazed that the pieces would hold together so tenaciously on such a thin sliver.
shipwright
#13 posted 08-18-2015 07:27 AM
No problem Charlie, I’m a bit like a reformed smoker.
I still occasionally use pva but if it’s important I’m a complete convert to HHG. :-)
View JoeinGa's profile
JoeinGa
7733 posts in 1909 days
#14 posted 08-18-2015 01:40 PM
I used to only use TB III, and only recently switched to TB II (strictly because of cost). One difference I immediately noticed was the III had a longer working time. I find the shorter working time with II to be frustrating sometimes, but they both cure stronger than Superman in the end.
View CharlesA's profile
CharlesA
3305 posts in 1699 days
#15 posted 08-18-2015 01:46 PM
I use standard Titebond most of the time because it is cheaper and plenty strong, and use III when I need water resistance or longer open time.
