Handle template for Stanley 13-052 Plough Plane
« back to Hand Tools forum
Forum topic by Jim Rowe posted 08-16-2015 05:08 PM 1680 views 0 times favorited 5 replies Add to Favorites Watch
View Jim Rowe's profile
Jim Rowe
1014 posts in 2186 days
08-16-2015 05:08 PM
Topic tags/keywords: plane
I recently picked up a boxed 13-052 Plough Plane with a complete set of cutters.
Although it’s not very old I would like to replace the plastic tote with something more pleasing to the eye.
Does anyone know where I can find a template for this tote?
Thanks
Jim
For some reason the picture I have inserted will only appear upside down and I can’t seem to fix it.
-- It always looks better when it's finished!
5 replies so far
Jim Rowe
#1 posted 08-16-2015 06:19 PM
I guess I can trace around the plastic handle and create a template that way, provided I can get the correct angle for the attachment bolt.
View bridgerberdel's profile
bridgerberdel
50 posts in 1116 days
#2 posted 08-16-2015 06:30 PM
I’d recommend making it first in some cheap soft wood. Once you have your jigs worked out and understand the process well move on to the real wood. Walnut looks nice as a plane tote.
-- occasional musings on my blog: www.bridgerberdel.wordpress.com
View upchuck's profile
upchuck
540 posts in 1539 days
#3 posted 08-16-2015 09:21 PM
Jim-
Lee Valley has templates for plane totes. Maybe you could adapt one for your purpose. Before I knew about the Lee Valley templates I would place the tote I wanted to copy on the glass of a Xerox (or other) copier and make a copy. For the angle of the fastener I’d find a snug fitting dowel that stuck out the top and bottom of the tote and copy that with the tote. If you had some grid paper to use in your copier then it would be easy to duplicate. Also rather than a straight strict copy think about how to modify what’s there to make a custom fit to your hand.
chuck
View fuigb's profile
fuigb
461 posts in 2831 days
#4 posted 08-16-2015 09:30 PM
Re: “correct angle”
It’s 90 or least you should make it that way. Bore the shaft first, then align the present handle to the hole to trace the outline. Super-easy / always works for me.
-- - Crud. Go tell your mother that I need a Band-aid.
Jim Rowe
#5 posted 08-16-2015 09:39 PM
Many thanks for all the very helpful suggestions here. I think I will now be able to create something more pleasing to the eye with these ideas.
Jim
