| Forum topic by EFA | posted 24 days ago | 642 views | 0 times favorited | 23 replies | ![]() |
24 days ago |
Topic tags/keywords: question heaters This is the first winter that I will have owned my table saw, and I must admit I’m not looking forward to the low temperatures the garage will reach. Anyhow, what type of heaters (brands/size) do the rest of you use to keep your garage/working space comfortable? We have a resonably deep three car garage. Many thanks in advance!! |
24 days ago |
Any 5kW electric heater will keep the chill out as long as the garage door isn’t going up and down forty times a day. If you have 220 in the garage, you might look at something larger than 5kW. When I lived in Indiana, I had a Black and Decker spacer heater that I used in my shop, one of the ceramic heater types. after about 30 minutes or so, it was comfortable, not hot mind you, but nice enough. -- Chunk |
24 days ago |
Here’s a link for a Berko heater: http://www.berkomep.com/develop/Products/UnitHeat/HUH524TA.htm -- Chunk |
24 days ago |
I have a large natural gas heater. but lots of people use wood heaters or propane space heaters -- Jim from Heirloom Woodshop Southern Oregon |
24 days ago |
Ive been looking at this one: http://www3.modine.com/v2portal/page/portal/modine/modineMarketsDefault/modine_com/markets/building_HVAC/market_level_3_content_013.htm -- Eagles may soar, but weasels don't get sucked into jet engines! Mike D. |
24 days ago |
I suggest 30,000 btu’s of hydronic base boards but you know. -- Dan, Sterling Alaska, http://sullcon.homestead.com/ Before you criticise some one, walk a mile in their shoes...then you will be a mile away and you have their shoes! |
23 days ago |
I have this one and it is excellent. https://www.gasoutdoorpatioheaters.com/xcart/product.php?productid=405 -- A mind, like a home, is furnished by its owner |
23 days ago |
I’ve got a 25×25 garrison on top of my garage in Maine (cold). I have an industrial electric heater downstairs in the garage for those rare winter welding times but here electricity is expensive to heat with. My shop has one of these: -- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://web.me.com/deceiver6/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html |
23 days ago |
I live in Ottawa, Ontario, Canada and our winters can get pretty nasty. We moved from a 1 car garage to a 2+ car garage three years ago and I struggle every year with trying to get the temperature to a comfortable working one. My 240v construction heater worked like a champ in the old garage but my new place is a challenge. It has open rafters and allows natural light in via the window at the front. If I close the ceiling up, I lose the only source of natural lighting, which would suck. Up until now, I have employed my construction heater and two radiant heaters (Lee Valley) to provide the heat but when we’re talking a -30 winter day, nothing short of a roaring bonfire will take the chill off and that’s a bit counter productive in the garage. The last two winters, I have closed off the ceiling using tarps. I installed two ceiling fans to try to blow the heat back down but because of the vastness of the space, all it does is create a cool breeze. This year, I’ve purchased a third radiant heater and it’s working pretty good, thus far. Time will tell though. I know I am going to have to either invest in a proper heating system (45000 btu) and/or close in the ceiling but I really hate closing off that window. -- -- Don in Ottawa |
23 days ago |
I have a Modine Hot Dawg gas heater. Works great. -- Wayne - Plymouth MN |
23 days ago |
You Canadians gotta remember that a lot of places in the U.S, electricity is expensive. I went to Quebec a ways back and found out that they’re a little bit peeved at us in Maine because we purchase electricity from them at more than double the price they pay, causing a rise in prices for them. At 6-12 Cents a kwh (depending on location) it’s not a cheap way to heat a house. -- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://web.me.com/deceiver6/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html |
23 days ago |
Not to change the subject but, at 10- 12 cents kwh it seems like a costly way to charge up an electirc car too. Bob -- A mind, like a home, is furnished by its owner |
23 days ago |
Bob.. compared to the cost of electricity it’s much less. at 10cents that’s equivalent to 150 miles per gallon. -- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://web.me.com/deceiver6/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html |
23 days ago |
Would that include the cost of replacement batteries and normal losses in acid cell batteries? I’m just learning about this technololgy so bear with me As is usually the case, the electircal providers will move the prices higher as the demand for product increases and the distribution costs start rolling in from under powered transmssion grids. Bob -- A mind, like a home, is furnished by its owner |
23 days ago |
Bob2. The new electric cars.. The chevy Volt for example will come out for sale to the public in 2010. It has a newly developed bank of lithium ion battery that doesn’t heat up and can withstand damage without exploding. The batteries weight 700 lbs and will provide 40 miles of travel on a charge. The reason 40 miles was decided on was after research 74% of people rarely travel more than 40 miles a day. The charge time is 6 or 3 hrs depending on 110 or 220 connection. One hour charge time for 80%. The car also has a 3 cylinder gasoline engine with the sole purpose of charging the batteries. So this car is totally electric with gasoline backup for the batteries only. The car gets approx 150 mile’s to the gallon equivalent in electricity and if the motor has to run to charge the batteries then it has a 50mpg rating and will go 400 miles on a fill-up. -- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://web.me.com/deceiver6/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html |
23 days ago |
Very interesting stuff. I find this really fascinating. Bob -- A mind, like a home, is furnished by its owner |
23 days ago |
You might want to look at the Mr. Heater MH18B. I have the older version, equivalent to the MH9BX, called the Portable Buddy heater. It is VERY effective at taking the shop from sub freezing, to mid 70s in less than a half hour at full tilt. Pretty cheap to run when running on a #20 cylinder as well. I am in a 2 car garage shop though… YMMV. -- Trying to follow the example of the master. |
23 days ago |
Heater….. oh yeah i know what your talking about. Florida here. Actually i have a small jet (forced air kerosene) heater that i use mostly when finishing projects. -- I can fix ANYTHING!.... Wheres the duct tape? |
23 days ago |
I use a kerosene Torpedo Heater on diesel. 165,000 BTU http://www.masterdist.net/allproheaters/forcedair/kerosene/pk165t.html Works fantastic and I can wheel it around if it is in the way. I have actually melted the end of 1/2 braided marine rope in front of it, on purpose. -- T. Nelson |
23 days ago |
Whoa Straightpiped, I have an older kerosene heater like that. I admit it needs cleaning but when it misfires and puffs a bit my eyes burn. Maybe the newer ones have eliminated those issues. Mine is also noisy. It sounds like a rushing jet engine. It does throw a lot of heat though. The metal cap on the end glows bright orange. It’s great for working on a car in dead of winter. Point it in your direction and you’ve got a bubble of hot air around you when outside of that bubble it’s below zero. -- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://web.me.com/deceiver6/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html |
23 days ago |
I was lucky in the house I bought 8 years ago had the same type as Bob#2 mentioned. https://www.gasoutdoorpatioheaters.com/xcart/product.php?productid=405 It works excellent. I have a 2 1/2 car garage in Michigan and it doesn’t take 15 minutes before the chill is gone and you can work. Uses a regular thermostat, so you just let it go. Clean, no fumes, no fuel to handle heats the entire space and quiet. Actually if you turn it up at all it gets too warm after a while. When zero (fahrenheit for the Canadians) outside, I can work in a light shirt. Steve. |
22 days ago |
Craftsman, My old garage had a natural gas wall mount unit. It worked well but took a while to get the garage warm, granted it was a 6 car garage. -- T. Nelson |
22 days ago |
Kerosene heaters are terrible for use in a woodshop because they introduce tons of moisture into the room. I’d stick with something that pipes the exhaust outside of the space you are heating. I have a forced air unit and an old potbelly stove that I use. Since getting the woodburner I don’t use the forced air unit anymore due to the fact that I get firewood for free. I had my shop at 90 degrees last winter when it was negative 15 outside, all thanks to a wood stove and a couple of fans. -- Julian, Park Forest, IL |
22 days ago |
HOT DAWG is what I have and it is wonderful!!!! -- Only the Shadow knows.................... |
| Forum | Topics |
Woodworking Skill Share
2912 |
3939 |
256 |
948 |
223 |
Woodworking Trade & Swap
619 |
Coffee Lounge
2383 |
LumberJocks.com Site Feedback
523 |
