| Forum topic by jerseyshore | posted 21 days ago | 471 views | 0 times favorited | 14 replies | ![]() |
21 days ago |
I always wanted to try using shellac as a finish, so when I purchased a couple of solid pine doors, I thought what a good opportunity to use shellac. I had planed on using shellac as a sealer because of blotch problems associated w.pine and then I was going to apply a stain to introduce a little color then finish w/ a few more coats of shellac. |
21 days ago |
You can either try trans tint to get the color you like, or try the amber shellac from bulls-eye on a scrap piece of pine and see if that’s the color you’re looking for. I did a couple pine doors in the amber tinted shellac and the color was great – but it obviously depends on what you’re after. Also, if you’re using the amber tinted shellac, make sure to thin it to about a 1lb-2lb cut – it made it a lot easier to use. -- Life is a one lap race. |
21 days ago |
I would do a lite sand on the doors with say 180 grit sand paper wipe down with naphtha then with denatured alcohol. Then you should be ready for a surface coat of dewaxed shellac. on the top coat use 3 lb cut and to help control blotch use 1 lb coat some times to coats. It’s always best to try a test coat on scraps first. -- Jim from Heirloom Woodshop Southern Oregon |
21 days ago |
Aniline Dyes can be dissolved in alcohol just like shellac. If you don’t mind mixing some of your own colors might be worth a shot. I have not tried it myself but it “seems” like it would work. Dave M -- I don't know where I'm going but I'm on my way! |
21 days ago |
Thanks, do i add the trans tint and then cut it down, or vice versa? |
21 days ago |
Dave is right but you need to strain through a paint strainer before you add the tinted alcohol before mixing it in you shellac .trans tint is different than aniline dyes which can be water, alcohol,or oil based -- Jim from Heirloom Woodshop Southern Oregon |
17 days ago |
I second the amber shellac suggestion. I use amber shellac on almost everything since discovering it a year or so ago. I think it adds a lot of ‘warmth’ and brings out the grain like nothing else I have found. If I am using it on a lighter wood I usually cut it with some clear at about a 3:1 clear to amber ratio, but that is a matter of taste. As far as the trans tints go, I usually add it to a pretty heavy cut so I can cut a smaller quantity and put on lighter coats first working my way up to full strength. |
17 days ago |
You can add dewaxed shellac on top of the shellac that you have already applied. It will bond and stick. You can then finish as you had originally planned. Zinnser sanding sealer is a dewaxed shellac. -- What happens in the workshop stays in the workshop. No wait that doesn't sound right. Karson Southern Delaware karson_morrison@bigfoot.com † |
17 days ago |
i would start over like jim mentioned, sand fine grit or alcohol wash. |
17 days ago |
I’m all behind a1Jim. The amber shellac would add a nice color.Keep in mind that pine always gains an amber tint over time on it’s own as well. -- Todd A. Clippinger, Montana, http://amcraftsman.com |
17 days ago |
This is great learning stuff. I use minwax & poly but want to experiment with aniline dyes to make the wood “pop” then what about topcoat that lasts & is tough? “Life is tough,... It’s a lot tougher if yer stupid” (John Wayne) -- $tudie |
16 days ago |
+1 on the amber shellac. Really warms up pine. I do 3 light coats of amber, 2 light coats of clear for depth. Wait a few days rub down with 0000 and wax. With a little practice it’s easy to brush or pad it on. Greg |
5 days ago |
note to studie i am sure many like poly but i dont. |
5 days ago |
Sure am glad I took the time to read this thread! I am building my workbench and I know generally workbenches don’t get a cabinet grade finish but what better project to experiment with finishes on in preparation for a kitchen cabinet remake. I looked at that can of stain I bought and said, Nope, not going to use it. Took it back to HD and brought back some amber shellac. I love that stuff!! It makes the wood gorgeous at least to me, now I have to see if the boss likes it on oak. Thanks for all the info in this thread. Frank -- My greatest fear is that when I die, my wife will sell all my stuff for what I told her I bought it for. |
5 days ago |
I am a huge fan of amber shellac. I took a class at Woodcraft on finishing and the instructor tried to show the simplest/foolproof finishing methods, those that have stood the test of time and are repairable. Shellac was heavily featured and after using it a few times I have found it addictive. Other finishes definitely have their place for certain uses, but I almost always turn to shellac now. It is so easy to work and works successfully with so many other finishing products. |
| Forum | Topics |
Woodworking Skill Share
2897 |
3909 |
255 |
941 |
220 |
Woodworking Trade & Swap
617 |
Coffee Lounge
2363 |
LumberJocks.com Site Feedback
522 |
