| Forum topic by SuperDave0002 | posted 23 days ago | 440 views | 0 times favorited | 16 replies | ![]() |
23 days ago |
Is there a fast and easy way to make boards look really aged and weathered like the 6th picture on this website? Thanks David -- David South FLorida |
23 days ago |
I WOULD TRY TO ASK THE PEOPLE WHO RUN THE SITE AS TO WHAT THEY DID OR USED FOR A FIN. -- Ike, Big Daddies Woodshop,www.icombadaniels@yahoo.com |
23 days ago |
Hey David -- Jim from Heirloom Woodshop Southern Oregon |
23 days ago |
Looks sand blasted to me -- Debt is nothing more than the 21st Century's form of slavery. |
23 days ago |
Yeah, use reclaimed wood -- Gary, DeKalb Texas |
23 days ago |
Could roughing it up with a wire brush get the same effect? -- David South FLorida |
23 days ago |
Says there that they used barn wood and birch bark. -- Dan-- Info for all @ http://www.hoistman.com |
23 days ago |
You might get it pretty good with a pressure washer, but I think a wire brush would leave too many tell tale marks. -- Debt is nothing more than the 21st Century's form of slavery. |
23 days ago |
23 days ago |
I have had good results on straight grained wood using a fine wire brush on a drill. If the grain is not straight I would use a sand blaster. You might try a power washer but then it would have to dry out for a week or two. -- Les B, Oregon |
23 days ago |
Get some chain link and beat it up, then some bike chain and beat it up. wire brush it, tie some nails together with string and beat it up, hit it with various tools, throw junk at it. Then do nothing but stain maybe several shades and finish with satin. Don’t plane, joint, edge, sand, scrape, nothing. Before any of this you could sandblast too. -- LAS |
22 days ago |
Simple. We use old wood, e.g. barns and driftwood. -- Randy, Rustic Artisan, a family tradition. (No PM's - auto-deleted.) - "I am a seeker, not a follower." |
21 days ago |
Agree with the sand blasters. My pop tried that with a project and it turned out really really well. |
19 days ago |
I make all kinds of stuff like this. I simply buy cheap rough cut barn board and run it through my planer a few times until it’s uniform in thickness, but still rough and then start building. Once I have the piece assembled I’ll do everything that skywalker suggested to distress it even more, give it a light sanding and then throw on some stain. |
19 days ago |
Wish I had some old barn boards, kinda hard to find here in south florida. -- David South FLorida |
19 days ago |
Up here in southern ontario, home depot sells rough pine which works about as well. The only problem is that it often seems pretty green. Personally, it doesn’t bother me much because the rougher my furniture looks, the better. |
19 days ago |
I make/carve decoys and occasionally will do a “doubtful antique”, which as you can imagine is a “fake” antique. So many times I need to show bare wood with an aged effect along side aged paint. Here’s a couple tips (experiment to see what works for you): A solution of vinegar and hydrogen peroxide will Grey the wood up nicely, or soaking it in nasty old coffee will give it a great deep aged look. Shoe polish is a great stain to give it an aged look, also amber shellac with a touch of Burnt Umber tube oil paint will also give it a cool coloring. A coat hanger cut off and inserted into a dowel can make a great tool to make worm holes when heated up with a torch. You can also bend the tip and make odd shaped worm “trails” in the wood. Judicious use of steelwool will polish the high points of the wood and contrast the low points. These are just a few things that I have used to achieve an effect. Good Luck! -- IN REMEMBRANCE OF MY NEPHEW: Cpl. Ben Desilets - USMC KIA 22 May 2007 Anbar Iraq |
| Forum | Topics |
Woodworking Skill Share
2909 |
3934 |
256 |
946 |
223 |
Woodworking Trade & Swap
617 |
Coffee Lounge
2377 |
LumberJocks.com Site Feedback
522 |
