HOLDFASTS IN 5 INCH BENCH TOP
Forum topic by tigerwoodsman posted 08-15-2015 04:59 PM 807 views 0 times favorited 7 replies Add to Favorites Watch
View tigerwoodsman's profile
tigerwoodsman
16 posts in 924 days
08-15-2015 04:59 PM
I ORDERED GRAMERCY HOLDFASTS FOR MY 5 INCH BENCH TOP I’M BUILDING, WILL THE HOLDFASTS WORK OR DO I HAVE TO COUNTER BORE FROM UNDERNEATH? THE HOLES ARE YOUR TYPICAL 3/4 WHAT SIZE BIT FOR THE COUNTERBORE UNDERNEATH?
-- Just because you shot Jesse James doesn't make you Jesse James
7 replies so far
View TheFridge's profile
TheFridge
8894 posts in 1392 days
#1 posted 08-15-2015 05:18 PM
I’d say a 1/4” x 2” rabbeting with bearing for a router. Or a 7/8” auger bit if you go that route. I have a 2-1/2”-2-3/4” top and the work like a champ. Pretty sure they’re work in a 3” top.
tigerwoodsman
#2 posted 08-15-2015 08:46 PM
What about a 1 1/2 forstner or spade bit from underneath?’
View RogerBean's profile
RogerBean
1605 posts in 2860 days
#3 posted 08-15-2015 09:03 PM
I’m using the Gramercy holdfasts in a 4 1/2” beech top and they work fine with no counterboring or other modification.
Roger
-- "Everybody makes mistakes. A craftsman always fixes them." (Monty Kennedy, "The Checkering and Carving of Gunstocks", 1952)
View Smitty_Cabinetshop's profile (online now)
Smitty_Cabinetshop
15116 posts in 2525 days
#4 posted 08-15-2015 10:23 PM
It’ll be tough to create a bigger hole than what’s in place with a forstner or spade.
Try them first, before modifying your bench top’s underside.
Usage over time will ream the holes a bit anyway, things will continue to improve.
tigerwoodsman
#5 posted 08-15-2015 11:34 PM
Another thing what grite are you using to rough them up? What do you suggest using on underside if it doesn’t work
Smitty_Cabinetshop
#6 posted 08-16-2015 09:48 PM
I think I worked over my painted holdfasts with 60 grit or so, but it doesn’t take much.
If reaming is needed, try a round rasp first?
View CL810's profile
CL810
3730 posts in 2894 days
#7 posted 08-17-2015 12:09 AM
I have the Gramercy holdfasts. They work great in my 3.5” bench top but would not hold in my 4.5” legs. I used a step bit and enlarged the 3/4” holes to 1” on the back side. + 1 to roughing up the holdfast.
-- "The only limits to our realization of tomorrow will be our doubts of today." - FDR
