Blindly cutting dado's on a router table
Forum topic by NBeener posted 27 days ago 371 views 0 times favorited 10 replies Add to Favorites Watch
View NBeener's profile
NBeener
386 posts in 72 days
27 days ago
Topic tags/keywords: router router table dado stop dado question
I’m building a tool box for my soon-to-be 2 y/o StepGrandSon (?):
The sides and ends will have dado’s to accept the ply bottom. The instructions say this about making those dado’s, with a straight bit, on the router table:
With the dovetails completed, next we’ll need to cut the dadoes to hold the bottom of the toolbox. Since these dadoes will not extend the entire length of the sides and ends of the toolbox, we’ll use a straight-cutting bit in a router to cut the dadoes.
[snip]
Place the inside of the stock (that you marked in a previous step) facing down toward the table and just above the router bit. Maneuver the piece so that the end of the piece is at the far mark on the fence, and ease the stock down onto the bit, holding it tight against the fence. Push the stock forward until you reach the back mark with the trailing edge of the stock, and then lift the piece off of the bit. Repeat with the other three pieces.
Uh. Okay.
Is this as much of a crap shoot as it sounds?? I did what they said, but … it’s not great. I have a bit less than 1/2” margin after my initial “under cut it, and then cut TO my mark” efforts (with contact lenses, glasses, AND flip-down magnifiers on !!).
I think it’s going to be okay, but … is there a better way to do this? I thought about doing it from topside with my plunge router, but … there still seems to be some slop in the equation.
Is that just the nature of a cut like this? Close is close enough??
Thanks much!
-- -- Neil
17063 posts in 476 days
27 days ago
Hey Neil
This might sound a little scary but is a fairly easy operation. If you try a practice piece of wood first you will see it’s just not that difficult. If in doubt cut short and re rout or just chisel a little. Try it you’ll like it.
View ChunkyC's profile
ChunkyC
277 posts in 153 days
27 days ago
I typically work off of center lines. Another method is to find the center of the router bit. If you have one of the router bits that comes to a point (sorry I can’t think of the profile name at the moment) you can use that to determine the center line of the router marking the fence so you can see it. Then mark the center lines of the start and stopping points on your workpiece.
I’ve never had much luck finding the front and trailing edges of the router bit accurately hence the center lining method for me.
-- Chunk
NBeener
27 days ago
Ahhhh.
Bingo, Jim. I should have stepped back, and used the chisel to finish it. I went back to the router, and didn’t have the control I needed to be accurate.
Definitely takes a little timeto figure out how/where/when to use power vs. hand. This would have been a good place: draw a line, cut it with a marking knife, chisel it out…..
Thanks much!
-- -- Neil
NBeener
27 days ago
Chunk: that’s great info, too.
I was doing my darnedest to measure exactly to the edge of the cutter on the straight bit. Using the center probably would have been easier!
I think I’m going to be fine (if not, I’ve got more of the wood, and can re-do. No biggie) ... as long as I don’t encroach on the area that’s got to be dovetailed.
-- -- Neil
ChunkyC
27 days ago
It’s a “V Grove Bit.”
-- Chunk
NBeener
27 days ago
This guy?
Interesting. I can see where that would make a difference. Thanks! I have a 30pc bit set, and—of course—that one’s not in it ;-)
-- -- Neil
27 days ago
If we are talking about a groove or dado all you need is a straight bit the correct size. even better a spiral bit
for cleaner cut with less tear out but not a necessity.
ChunkyC
27 days ago
You only use the v grove bit once to find the center of the router and mark the center line on the fence. Once you have the c/l, you install your straight bit and cut away.
NB: That’s not necessarily a v groove bit per se. but any bit that comes to a point would work and that one would work. Well that is if you had one.
I’ve never tried it, buy maybe you could grind something to a point ??. Anything that comes to a nice point that is centered would do.
-- Chunk
NBeener
27 days ago
Ah. Gotcha. Thanks, Chunk!
Thanks, too, Jim. I hadn’t heard of a spiral bit, but found a great Pat Warner description of the difference, here (for others who don’t know….):
http://www.woodcraft.com/Articles/Articles.aspx?articleid=445
-- -- Neil
27 days ago
We all have different approaches ,but I use the bit I’m going to cut with and hold a square on each side of a bit making a mark on the fence indicating were to stop for each side of the cut and then proceed.
