12" Sears Electronic Band Saw
Forum topic by andy_P posted 21 days ago 359 views 0 times favorited 20 replies Add to Favorites Watch
View andy_P's profile
andy_P
40 posts in 100 days
21 days ago
My band saw is stating to stall during cuts. The motor keeps running but the bottom wheel and the blade stalls. I bought this unit from someone who did not have the manuals. It sounds like the belt is slipping, or, could this be caused by a dull blade? I have found this both with a 1/4” blade and a 1/2” blade. I was working with hardwood but I was able to cut through it like butter when I switched to my stationary scroll saw.
I have two quetions:
1. Can anyone give me some ideas on where I can start to look into a fix.
AND
2. Where do you think I might find a manual for the machine. I cannot make out the Model Number on the sticker on the side and I don’t want to start tearing into it without a manual. I have tried an on line search but no luck.
-- Wood is a gift from God/Nature that maintains its beauty forever via the hand of a woodworker.
View SCOTSMAN's profile
SCOTSMAN
2238 posts in 478 days
21 days ago
sounds like a slipping belt.Can’t you watch the belt and the wheel as it turns sometimes you can’t try tightening the belt or get anew one.Alistair
andy_P
20 days ago
Your response was fine, Scot, and very much appreciated.
There is no way for one person to watch the belt and the wheel at the same time. I too was thinking the belt is slipping. I wonder if I can get some of that automotive belt dressing to see if that helps. Without the manual, I don’t know how to go about tightening the belt. The whole thing is in a cabinet and the access door does not let you see the “guts” of the machine.
Thanks for the response.
16598 posts in 469 days
20 days ago
It could also be the tires on your bansaw wheels nead replacing.
Dick, & Barb Cain
7034 posts in 1192 days
20 days ago
The set screws on the drive pulley, or the driven pulley could have loosened.
andy_P
20 days ago
I figure if it was the tires, the wheel would be turning and the tires slipping but that is not the case.
I’m going with Dick’s suggestion but without the manual I am a little bit of trouble. You can hardly see under the cabinet and I don’t want to start tearing the whole thing down. I figrue there must be some sort of accessable area to make the adjustment but I don’t know where.
View scrappy's profile
scrappy
1580 posts in 323 days
20 days ago
Check on sears.com for the manual. The have a section for parts and service and usually have manuals for the more recent equipment.
If it is older try www.OWWM.com They have a lot of manuals also.
Scrappy
-- Scrap Wood's the best...the projects are smaller, and so is the mess!
View ajosephg's profile
ajosephg
440 posts in 453 days
20 days ago
I wouldn’t use belt dressing. Based on my experience with cars all it does is make a mess. If the belt is not loose it is probably glazed and needs to be replaced.
-- Joe
andy_P
20 days ago
Ah ha! Joe, you might have hit it. I will have to get a hold of a manual and see how to change the belt. It’s worth a try.
Scrappy, thanks. I’ll give that web site a try. Sears definitely doesn’t have it…...at least I have not found it.
View drfixit's profile
drfixit
122 posts in 36 days
20 days ago
May be able to find some info on the saw on Searspartsdirect.com Enter the model number of the saw, it will show breakdowns of the parts and possibly the manual
-- I can fix ANYTHING!.... Wheres the duct tape?
andy_P
20 days ago
Scrappy, That web site is murder to get registered on….but I’m trying.
drfixit…..that is one of my problems. I can’t read the Model Number.
View LesB's profile
LesB
537 posts in 335 days
20 days ago
I bet on the pulley. They usually have a set screw that secures them on the motor shaft. If the set screw is loose the pulley will spin; it may even be missing. Try that first. Most need an allen wrench to tighten. Then replace the belt if that is not the problem.
Definitely don’t waste money on belt dressing.
-- Les B, Oregon
andy_P
20 days ago
Thanks, Less. I’ll see if I can gain axccess to it without getting into too much trouble.
View Autumn's profile
Autumn
83 posts in 44 days
20 days ago
I had the same problem on a Craftsman 12” bandsaw. The motor ran but the blade stopped turning when I pushed a piece of wood into it. When I found the problem I was surprised. The “key” had fallen out of the shaft that turns the pulley. Some may have set screws, but mine just had a rectangular key. Here’s where I found the part:
http://www.searspartsdirect.com./partsdirect/index.action.
Autumn
83 posts in 44 days
20 days ago
Here’s the link to the manual for the 12” Craftsman electronic bandsaw, Model # 113.247410 (the only one they manufactured with “electronic” in the name). The part you are looking for, possibly, is part #45: 3/16” x 15/16” key. Those little buggers fall out whenever you move the saw around.
http://www.hammerwall.com/Download_Manual/44271/
andy_P
20 days ago
Autumm, you are a Peach!!!! Yes, mine is a Craftsman.
I’ll get to work on your info asap. The way you describe the problem is exactly what I am experienceing.
Thanks a bunch.
View Don Newton's profile
Don Newton
528 posts in 511 days
20 days ago
Lumberjocks…..it don’t get much better!
-- Don, Pittsburgh
andy_P
20 days ago
You got that right, Don. Even though we are not all “jocks”
That link that Autumm gave me took me right to the manual and it is now downloaded and in my hands. Time to go to work.
Thanks to all for your respnses. I will soon close out this topic.
Dick, & Barb Cain
19 days ago
When you get it apart, see if there’s enough room on the pulley hub, so it can be drilled & tapped for a set screw.
View LesB's profile
LesB
19 days ago
As I look at the diagram (rather blurry on the sears site) there is a set screw that holds the key in place. Both of those parts can be found at most hardward stores.
-- Les B, Oregon
andy_P
19 days ago
Thanks to Autumn, I have printed out the complete manual. I think I will be ok from here…....I Hope!
