5' x 5' vs 4' x 8' plywood sheets
« back to CNC Woodworking forum
Forum topic by SteveMI posted 08-12-2015 08:04 PM 929 views 0 times favorited 1 reply Add to Favorites Watch
View SteveMI's profile
1086 posts in 3230 days
08-12-2015 08:04 PM
I have found that the glues used for the two sizes of plywood are different. Seems 5’ x 5’ is glued with Urea Formaldehyde Adhesive, and 4’ x 8’ is glued with Phenol Formaldehyde Resin. Both glues are industrial.
I learned the glue information through a bad experience with 4’ x 8’ sheet material not getting repeatable cutting with a laser. Even with higher power there would be sections that did not cut. Switching to 5’ x 5’ sheets with recommendation by the laser machine rep solved the issue, lesser power and repeatable full cutting.
And I had a better experience on the CNC with the left over 5’ x 5’ format sheets. Bits seemed to be cleaner after cutting and I could cut at a slightly faster rate.
So, for the cabinet shop and furniture guys that use a CNC, does this make sense? Is my limited sample size on the CNC too small?
And to go on tangent, is either a better substrate for veneer?
1 reply so far
View greg48's profile
599 posts in 2694 days
#1 posted 08-12-2015 09:16 PM
Steve, I’m only aware of the Baltic birch ply being offered in the 5×5 format, while the 4×8 formats are offered for construction and cabinet grade plays. The glue types may be a factor, but the fact that there are no voids in the Baltic birch may be more significant. That will be $0.02 please.
-- Greg, No. Cal. - "Gaudete in Domino Semper"
