Help identifying chisels
« back to Woodturning forum
Forum topic by macdo posted 08-12-2015 12:41 PM 1078 views 0 times favorited 10 replies Add to Favorites Watch
View macdo's profile
macdo
29 posts in 2148 days
08-12-2015 12:41 PM
Topic tags/keywords: chisel question tip turning
Hi guys, I bought in an ebay auction 8 Robert Sorby Chisels + 1 japanese, but as Im kinda a newbie, is hard to identify the gouges… I’ll appreciate if you could help me.
And this beast…is it an skew chisel or scraper?
Thanks in advance and best regards,
macdo
10 replies so far
View TheDane's profile
TheDane
5552 posts in 3869 days
#1 posted 08-12-2015 02:02 PM
The ‘beast’ is not a skew … looks like a heavy square scraper.
Of the other four tools, #2 looks like a spindle roughing gouge. The other three appear (can’t tell for sure what #1 is) to be old fashioned spindle gouges. Also can’t tell if these are carbon steel or HSS.
macdo
#2 posted 08-12-2015 02:07 PM
Hi, thanks for the fast answer, they are HSS, Im uploading another pic with a different angle to see if it helps…
Thanks!!
View Ron Ford's profile
Ron Ford
209 posts in 1938 days
#3 posted 08-12-2015 03:27 PM
From the angle of the new photo, I’d guess the first two on the left to be roughing gouges, the third one a scraper, and the fourth a detail spindle gouge. I agree with TheDane that the wide flat one in the first post is a wide flat scraper.
Ron
-- Once in awhile I make something really great. Most days I just make sawdust.
macdo
#4 posted 08-12-2015 04:15 PM
Oh bummer, I though the first one was a bowl gouge, is there a way to grind it to make it work as a bowl gouge?
Thanks!
View ForestGrl's profile
ForestGrl
450 posts in 1292 days
#5 posted 08-14-2015 05:04 PM
I’m a relative newbie, but what I’ve read and been told about roughing gouges is that they are relatively weak—note the smallish tang that inserts in the handle. It might be unsafe to convert and use it as a bowl gouge, which have a stronger design.
-- My mother said that anyone learning to cook needed a large dog to eat the mistakes. As a sculptor of wood I have always tried to keep a fireplace. (Norman Ridenour)
TheDane
#6 posted 08-14-2015 05:29 PM
No … you would be creating a hazard that could injure you. ForestGrl is spot on … the tang (where the steel goes into the handle) is a weak point and a good catch could bend or break it and rip it right out of your hands.
View waho6o9's profile
waho6o9
8525 posts in 2783 days
#7 posted 08-14-2015 05:32 PM
http://www.thompsonlathetools.com
Thompson bowl gouges are of good value.
Good luck now :)
ForestGrl
#8 posted 08-15-2015 02:56 AM
How are your sharpening skills, have you any gouges yet that you’ve worked on? One thing I learned, the easy way for once, is to learn to sharpen on cheap chisels (this coming from a very sharpening-challenged person!). Although there is an argument that it’s not that expensive to learn on an expensive gouge. I just got less frustrated when the steel continued to disappear and I still didn’t get it. :-( If your tool isn’t sharp, you’re wasting your time spinning wood! (oooo, that was a little strong). But it can be a little unsafe too.
TheDane
#9 posted 08-15-2015 11:49 AM
If your tool isn’t sharp, you re wasting your time spinning wood! (oooo, that was a little strong). But it can be a little unsafe too.
Spot on … as Mike Peace says: “If it’s almost sharp it will almost cut”.
ForestGrl
#10 posted 08-16-2015 06:52 AM
If your tool isn t sharp, you re wasting your time spinning wood! (oooo, that was a little strong). But it can be a little unsafe too.
Spot on … as Mike Peace says: “If it s almost sharp it will almost cut”.
- TheDane
I’ve noticed it also tends to burnish the wood, probably because, being dull, it must be held more firmly against. Not a good thing.
