Threaded inserts strong enough for table top?
« back to Joinery forum
Forum topic by Aodskate posted 08-12-2015 04:22 AM 2327 views 0 times favorited 10 replies Add to Favorites Watch
View Aodskate's profile
Aodskate
22 posts in 1559 days
08-12-2015 04:22 AM
Topic tags/keywords: question mahogany oak joining rustic
Hoooowdy folks, I am currently working on a trestle style coffee table. I would like the table to be able to come apart of needed so I’m looking for some threaded inserts strong enough to hold some fairly decent bolts. The table is 1 1/2” thick and the legs/bases are made out of 3×3 pieces of solid white oak. The uprights will be joined to the base on the floor and the base that the table will sit on with a through tenon with a couple dowels ran threw that. The table will be solid as all hell I just need to find a sturdy enough way to attach the bases to the top.
Hopefully that made sense and someone has some suggestions? All the threaded inserts I’ve seen have been too small for the size of bold id like to use.
10 replies so far
View Wildwood's profile
Wildwood
2532 posts in 2377 days
#1 posted 08-14-2015 07:10 PM
Not sure these things will fit you with your design finding hardware online not so easy.
http://www.wwhardware.com/jacob-holtz-apron-brackets-jhtablefasteners
http://woodworker.com/folding-wooden-leg-fitting-mssu-937-418.asp
http://www.rockler.com/kerf-mount-corner-brackets-for-table-aprons-kerf-mount
Have you thought about simple metal or wood brackets and screws might be the ticket and less expensive.
-- Bill
View AlaskaGuy's profile
AlaskaGuy
5005 posts in 2551 days
#2 posted 08-15-2015 06:52 PM
Ya got a picture or a drawing of the table? From your description I’m not sure exactly which joints need to be knock downs.
View bondogaposis's profile (online now)
bondogaposis
5157 posts in 2593 days
#3 posted 08-15-2015 08:59 PM
If you are talking about attaching the top to the trestles, make sure you allow for movement or the top will split eventually.
-- Bondo Gaposis
Aodskate
#4 posted 08-16-2015 02:55 AM
Excuse the crude drawing but I think you can get the idea
AlaskaGuy
#5 posted 08-16-2015 04:36 AM
If I understand you are asking how to attach the table top the trestle.
As bondogaposis points out you need to allow for wood movement.
Take a look at the pictures of the figure 8 fasteners in this thread.
http://community.woodmagazine.com/t5/General-Woodworking/Wife-wants-a-table/td-p/436639
View jumbojack's profile
jumbojack
1685 posts in 2866 days
#6 posted 08-16-2015 06:20 AM
If you go with your drawn plan you should wallow the hole going through the trestle. If you don’t and the top expands or contracts bad things are likely to happen.
Wildwood
#7 posted 08-16-2015 12:05 PM
You are talking about making a single pedestal coffee table. Would use 4 insets in top and use two stretchers attached to pedestal so could mount the top with 4 bolts. One wide stretcher mounted to pedestal would also work well. Really not hard to drill the stretcher(s) to allow for movement.
-- Bill
Aodskate
#8 posted 08-16-2015 11:07 PM
No I’m not talking about a single pedestal table… I’m talking about a trestle table, my drawing is just ugly. I think I’ve got er sorted though
AlaskaGuy
#9 posted 08-16-2015 11:34 PM
I think you’ll find you answer in this plan.
Check out the “Apply finish and attach the top” part.
http://www.popularwoodworking.com/projects/shaker-trestle-table-aw
View fsutim's profile
fsutim
17 posts in 1347 days
#10 posted 08-19-2015 02:13 AM
Maybe consider using four T-nuts which you can add epoxy to help make sure they stay in the underside of the table.
