Kreg Pocket Hole Screw size?
Forum topic by david51st posted 23 days ago 402 views 0 times favorited 13 replies Add to Favorites Watch
View david51st's profile
david51st
13 posts in 388 days
23 days ago
Hello,
I am looking to get the Kreg pocket hole system but have a question? What size screws do you need for 3/4 and 1 inch face frame work, white oak material? and is it #6,#8 fine or course? They have info on depth for drill but can not seem to find screw size.
Thanks,
David
View UnionLabel's profile
UnionLabel
148 posts in 93 days
23 days ago
Fine is for hardwood, and coarse for plywood. I use #6’s for most projects, but 8’s for shop cabinets and some jigs, cause I know I’ll abuse the jig a little.
-- Easy Peasy Lemon Squeezy-May all your dovetails fit tight and right the first time
david51st
23 days ago
How long? 1 1/4?
Rick Dennington
318 posts in 87 days
23 days ago
UnoinLabel is correct, but I’ll carry it 1 step further. Besides ply, course is also for softwood like pine, fur, etc.
I’m doing a job now, and I’m using #7×1 1/4”. These are fine threads, cause I’m using oak. If you get the K.p.h.s., it’ll have instructions in there, and tell you screw sizes and lengths to use. Hope this helps.
-- Remember--- one good turn-- gets most of the blanket!!!!
16683 posts in 470 days
22 days ago
I would use the 1 1/4” also
View davidroberts's profile
davidroberts
242 posts in 379 days
22 days ago
Kreg recommends 1 1/4” for joining 3/4 material. I just finished drilling about 300 holes, or was it 400, for a shelving project. I’m not using glue.
-- david roberts, houston area, "A little knowledge is a dangerous thing, but that has never been a problem for me."
View Bob Kollman's profile
Bob Kollman
98 posts in 84 days
22 days ago
When you buy the jig it gives you all the imfo on a chart. It’s a nice system to own.
-- Bob Kenosha Wi.
View hootr's profile
hootr
131 posts in 239 days
21 days ago
it’s good system with all the info included
i ususally get my screws from
www.mcfeelys.com
big selection with shipping offers once your in their mail list
-- Ron, Missouri
View SouthpawCA's profile
SouthpawCA
32 posts in 126 days
21 days ago
I had a similar question about screw size. What I was told is, use the size of screw to match the size of the smallest wood. So, if you are joining 3/4” to 1/2” use the screw for the 1/2”. However, what screw is that??? Well, here is a link that sorta tells which screw to use:
http://www.kregtool.com/products/ka/ScrewChart.pdf
Let us know what you think.
-- Don
View Mitch Neal's profile
Mitch Neal
6 posts in 21 days
20 days ago
When you decide what size and length look at MCFeelys to buy. They have got great prices if you buy in bulk. I usally get the 1000 piece box I think it was around 28-30 bucks.
-- Its not your lifes goal, its the path you take to achieve that goal that really matters. Mitch Dayton OH
Rick Dennington
20 days ago
SouthpawCA: What I usually do is start with the 1 1/4” SRS typewhen working with 3/4” stock. Try 2 different sizes in the stock you’re working with: If 1 1/4” is too long, and starts to come through(watch it carefully), then drop back to the 1”. I think you will figure it out. Just make sure it’s a pocket hole screw, and not a wood screw—they won’t work. Hope this helps some. Trial and error—I do it all the time—- mainly error!!!!
View SnowyRiver's profile
SnowyRiver
3336 posts in 373 days
20 days ago
I agree with Bob. There should be a chart with the tool that gives you all of the sizes and types of screws to use based on the wood thickness and type. I use it all the time…its a great tool.
-- Wayne - Plymouth MN
View Don Newton's profile
Don Newton
528 posts in 511 days
20 days ago
Take a look at the Harbor Freight Pocket Hole tool that was reviewed a few times on this site. That’s the one I’m buying with my 20% off coupon. Should be around $56.00.
-- Don, Pittsburgh
View bill merritt's profile
bill merritt
59 posts in 182 days
13 days ago
Has anyone tried building drawers with the jig,think I saw it in one of there ads? But not sure.
-- Bill Merritt -Augusta Ga. woodworker
