Locking Pin Replacement for Millers Falls Miter Box
« back to Hand Tools forum
Forum topic by UltraMagnus posted 08-11-2015 05:07 PM 1027 views 0 times favorited 8 replies Add to Favorites Watch
View UltraMagnus's profile
UltraMagnus
4 posts in 1254 days
08-11-2015 05:07 PM
Topic tags/keywords: miter box millers falls replacement parts lock pin restoration
I picked up an All Steel miter box by Millers Falls, cleaned it up and now it’s really nice. The locking pin seized, but I was able to move it in a vise. However, once on the miter box it is unmovable.
Where can I find a replacement locking pin?
Or how can I fix this one?
The locking pin is what secures the lever at the desired angle. If it doesn’t work the miter box is useless.
Or how can I fix this one? I’ve tried massive amounts of PB Buster, butt I think it has done all it can do.
8 replies so far
View TheFridge's profile
TheFridge
10814 posts in 1720 days
#1 posted 08-11-2015 05:22 PM
I’ve heard acetone/ ATF mix works wonders.
View Bill White's profile
Bill White
5148 posts in 4194 days
#2 posted 08-11-2015 05:29 PM
Have you tried any heat to the area?
Bill
-- bill@magraphics.us
UltraMagnus
#3 posted 08-11-2015 05:38 PM
I have not tried heat. I don’t know what the inside of the locking pin holds. Do you think it is a broken spring or just a dirty rusted interior? If it’s a broken spring I would need disassemble right? I don’t know the proper way to disassemble one of these.
UltraMagnus
#4 posted 08-12-2015 12:55 PM
This is the pin fully pushed through.
View JethroBodean's profile
JethroBodean
136 posts in 1246 days
#5 posted 11-18-2015 07:28 PM
So I’m just curious, what, if anything, was the final outcome?
I assume this pin is from under the swing arm, is it not? Looks way too big to be from the Saw Guide Posts.
The pins on my Goodell All Steel look different than this.
-- I am not much of a woodworker, but I'm great at making sawdust! -- Jeff
View shuf's profile
shuf
3 posts in 1143 days
#6 posted 11-30-2015 12:21 PM
I recently acquired a nice Miller Falls Langdon Acme 74C Miter Box and it is missing a 16847 Depth Gauge Screw. I have one but am missing the other one. Does anyone know where I can find a replacement depth gauge screw? I am nearing completion of the restroration and would like to have the miter box in top notch working condition.
View JoeinGa's profile
JoeinGa
7739 posts in 2241 days
#7 posted 11-30-2015 12:40 PM
I’m wondering the outcome as well. Looks like from the picture a good rubbing with some steelwool would have cleaned that pin.
UltraMagnus
#8 posted 12-30-2015 07:21 PM
Hey JethroBodean and JoeinGa, thank you for checking in. I didn’t post my results as I didn’t think there was much interest.
The internal mechanism was not what i thought it would be. I thought there was a spring of some sort. There was nothing. Just the pin and the nut. I pushed the pin out by offsetting the nut in a vice and cranking it. You can see this in the pic above. Once it was flush i stuck a bolt in there and used that against the vice until the pin popped out the other side. A few strokes with some fine grit sand paper and smooth steel wool was enough to clean it and ensure it slides smoothly through the nut. Works great now.
