Do you make scale model for every project?
Forum topic by woodworm posted 23 days ago 350 views 0 times favorited 18 replies Add to Favorites Watch
View woodworm's profile (online now)
woodworm
8138 posts in 482 days
23 days ago
Topic tags/keywords: question tip and trick
In making a furniture, sometime we begin with the idea, translate it into sketch drawings by incorporating the concepts (if any) with the usage, materials used, finish and colour. It is indeed a tedious process and time consuming.
And sometime we make a scale model or even full size mockup to visualize the dimensions and proportions of every part of the piece is in harmony.
Any of you guys/gals strickly follow the above path? Does the sketch drawing, model or mockery really helps you making the actual furniture looks better? Or in other word, does the success of furniture making depends upon this initial stage?
Share your experiences with us!
-- masrol, kuala lumpur, MY.
TopamaxSurvivor
2994 posts in 568 days
23 days ago
I design on the fly. Very seldom even draw a plan, much less make a model:-)
View Chris Wright's profile
Chris Wright
358 posts in 373 days
23 days ago
I’ve never made a model, but I almost always make a scale drawing.
-- "At its best, life is completely unpredictable." - Christopher Walken
View Chris 's profile
Chris
1462 posts in 883 days
23 days ago
I have actually have taken to using SketchUp my prototyping work….
-- Chris
View cabinetmaster's profile
cabinetmaster
8462 posts in 450 days
23 days ago
Draw to scale and go from there.
20538 posts in 714 days
23 days ago
I have to develop a drawing to work with. From this I will use the Sketchup drawing to work up a material and cut list using Cutlist. But I have never made a scale model of any of the furnitue that I have built.
View ChunkyC's profile
ChunkyC
272 posts in 146 days
23 days ago
I always work from some sort of drawing. I don’t make scale models but I do make some parts out of scrap first especially if it’s something that I’ve not tried in the past or a new “technique”. The one thing that I do do is I make a “dry run” of most every cut. I will set up table saw up with the blade all the way down and run the workpiece through the saw. I’m checking for interferences, how the piece fits against the fence, do I need a push stick, etc.
-- Chunk
25794 posts in 1292 days
23 days ago
I usually make a sketch, I’ve only made a model for a lingerie chest that I was making for my daughter and daughter-in-law. I wanted them to visualize it.
View cstrang's profile
cstrang
1202 posts in 60 days
23 days ago
It all depends on the project for me. If it is for a customer I will draw it using Google SketchUp and get their approval on the final design before making it so after it’s done they can’t say “thats not what we agreed upon” then I simply bring out the drawing with their signature on it and say “yes it is”. On the other hand if it is something I am building for myself or a gift I rarely even sketch it on a piece of paper, everything is neatly organized in my head, this doesn’t work for everybody but it works for me.
-- A hammer dangling from a wall will bang and sound like work when the wind blows the right way.
View rowdy's profile
rowdy
84 posts in 334 days
23 days ago
I never have made a model. I usually make a rough sketch that shows the overall dimensions and a few design ideas, but beyond that I build on the fly. However, I do stop and think a lot about what lies ahead after I complete a given section of the work, for example the frame of a cabinet. It is sort of like chess; I can think about three or four steps ahead and in woodworking that seems to be far enough. In chess it is not and that may explain why I am such a lousy chess player, or as the good players put it, I am just a wood pusher. True statement I guess in more ways than one.
-- Rowdy in Kechi, Kansas
View lew's profile
lew
4474 posts in 647 days
23 days ago
Like most of the responses, I make a sketch and work from that.
Sometimes, when the layout/fit is critical, I make a full size drawing. I find this really helps get the measurements correct.
DaveR has helped me with some Sketchup drawings and I try to use it when I have lots of time.
Lew
16577 posts in 469 days
23 days ago
Rarely do I make models but have on a couple of occasions
View papadan's profile
papadan
440 posts in 260 days
22 days ago
I draw up a set of plans if requested before the piece is delivered.
-- Dan-- Info for all @ http://www.hoistman.com
View john's profile
john
1183 posts in 1273 days
22 days ago
I design as i go . Most of the stuff i do is scaled down as it is .
-- John in Belgrave ,(Slideshow ) http://cid-69bce320c6d8b119.skydrive.live.com/play.aspx/Extreme%20Birdhouses/P1030026.JPG?ref=2 (Website) http://www.extremebirdhouse.com
Todd A. Clippinger
5632 posts in 991 days
22 days ago
I hand sketch and do clean drawings.
I have made several models for expensive projects but got paid for it. The clients wanted to insure they were comfortable with the way they were spending their money.
The model or drawing never hits 100% of the finished project. Once I get the drawing close enough, we make design modifications on it and I just note it on the drawing, sketch, or in the notebook for models. Then I just go straight to making the project.
The model or drawings are a platform to work from but it is only once in a while do I have drawings or a model that is 100% complete and accurate to the finished project.
Small shops can get away with this. Start adding employees and everything needs to be completely detailed.
Most of my work is sold on rough sketches and designing on the fly. I only need key measurements. I think that you will find many experienced cabinetmakers or craftsman that have small shops work this way.
I have not taken the time to learn Sketchup but I plan on it. I realize it’s potential as a communication tool.
View rosewood's profile (online now)
rosewood
210 posts in 233 days
22 days ago
i have never made a model, just grab the wood no matter big or small and make what on mind,
Rosewood,
-- http://picasaweb.google.com/deniirawan66
View huff's profile
huff
1608 posts in 177 days
22 days ago
Todd is right, I’m a small one man shop, so the only reason I do drawings is more for the customer to see what it will look like. I have a CAD system that is designed for cabinetry layout, so will use that for kitchens and basic cabinetry work, but for furniture I will do sketches. I’ve done a few models before, but not too often. I just designed a contemporary end table, coffee table and chest of drawers for a customer and did a small model of the coffee table to show her. She loved the model and I’m sure it helped to close the deal…...or maybe it was just my good looks! LOL.
-- John @ Myrtle Beach
View John Ormsby's profile
John Ormsby
503 posts in 629 days
22 days ago
I agree with Todd. I work pretty much the same way. A sketch and some details and off to the project. Trying to design something completely can take too much time. My clients are always making some change or another.
-- Oldworld, Fair Oaks, Ca
View RBWoodworker's profile
RBWoodworker
215 posts in 244 days
18 days ago
Well..in my case..for the furniture sucks as chairs and tables..I usually have templates of pieces I’m making that I use to shape the parts off of..but most of the time..I make according to the deminsion im my mind..I know how I want a piece to look and how to go about making it..I first build it in my mind..then go from there..the tv lift curved cabinet I got the idea from Les Hastings.. and I took it from there and did it by the seat of my pants..
-- Randall Child
