Boot Bench modification
« back to Hand Tools forum
Forum topic by Ray posted 08-11-2015 04:36 AM 824 views 0 times favorited 5 replies Add to Favorites Watch
View Ray's profile
Ray
126 posts in 1967 days
08-11-2015 04:36 AM
I really like the look of this bench (Found on Lost Art Press blog). If I was to build a shorter version (left to right) can anyone help me with the calculation required to maintain the pleasing appearance of the arc? If I just shorten it, I am guessing it will lose its appeal and destroy the look.. or is it not possible?
Thanks
-- Creating less fire wood every day
5 replies so far
View Woodknack's profile
Woodknack
11479 posts in 2344 days
#1 posted 08-11-2015 07:23 AM
There are several ways to do it. Simplest is use a flexible ruler or strip of plywood anchored at both ends.
http://www.woodsmithtips.com/2014/04/17/shop-built-layout-gauge/?utm_source=WoodsmithTips&utm_medium=email&utm_campaign=8098
Or you can get a little more complicated
http://www.popularwoodworking.com/articleindex/jig-journal-arc-drawing-bow
View oldnovice's profile
oldnovice
6759 posts in 3332 days
#2 posted 08-11-2015 05:44 PM
Even if there was no arc it would just be your version.
If you really, really, want an arc, use Rick’s method above ‘cause that’s the easiest, simplest way to make an arc.
4949 posts in 2457 days
#3 posted 08-11-2015 06:12 PM
It almost looks like the arc on top matches the one on the rail under the seat. Holding my hands up to cut off each end (my visual test) doesn’t make it look any less pleasing to me.
View Mattyboy's profile
Mattyboy
50 posts in 1042 days
#4 posted 08-11-2015 08:34 PM
Maybe you could sketch out your proposed design and see what you like for the curve. I use Sketchup software to look at my designs and that really helps to see it. But all you really need is a piece of paper and pencil and ruler.
-- Matt, Northern CA
View Johnny7's profile
Johnny7
361 posts in 1054 days
#5 posted 08-11-2015 08:58 PM
Fred has the right idea
The following refers to the arched horizontal rail under the seat in your original photo.
on your shorter version, you don’t want the ends of the under-seat arched piece to be as tall as they are on the original, since that would close off the opening.
to scale down this version: copy/trace the arch onto masonite or cardboard.
To lay out the rail on the new shortened version, measure the distance on the original, from the underside of the seat to the top of the arch. Mark off this distance on your rail, then, using your template, trace the arch onto your new workpiece, letting the arc define the height at each end.
