| Forum topic by eddy | posted 25 days ago | 281 views | 0 times favorited | 10 replies | ![]() |
25 days ago |
Topic tags/keywords: tip |
25 days ago |
We lost it in this county 2 years ago- |
25 days ago |
To be safe raise and knock it back down before applying water based stain/poly. Also, does the Prop 65 focus on Poly eliminate it from sale or just restrict the size of the containers like with oil based stains? |
25 days ago |
hate waterbase,just aint the same.if its going from cali then the rest will follow. -- eric post, tallahassee FL |
25 days ago |
I quit using oil base finish 6 years ago and don’t miss it a bit. Water base is just as good and a whole lot better for the body and enviroment not to mention clean up. -- You don't have to be crazy to work with juniper, but it sure helps. |
25 days ago |
I’m not surprised. Thanks for the heads-up. -- "The only thing that counts is faith, expressing itself in love." --Galatians 5:6 |
25 days ago |
I’ve used it for a long time too. A good product and a lot less fumes. -- Jim from Heirloom Woodshop Southern Oregon |
25 days ago |
I find that it works better if you don’t raise the grain in advance. If it does raise the grain it hardens in the raised position making it very easy to sand off. You will have to sand for a second coat anyway. Another good thing is that by running your hand over the surface it’s real easy to feel the rough spots if you missed sanding any. It dries real fast, but usually takes a coat or two more to complete it. -- Gary, East TX -- The longest journey begins with a single step. |
25 days ago |
I noticed that Lowes in Salisbury MD, was selling all of thier Minwax stain for about 25% of regular price. -- What happens in the workshop stays in the workshop. No wait that doesn't sound right. Karson Southern Delaware karson_morrison@bigfoot.com † |
25 days ago |
I’ve been using ML Campbell water based lacquers for years. It’s no biggie to switch to GOOD water based products. The good stuff handles better, is available in water clear or amber tinted, is far more consistent batch to batch, and raises less grain. There’s a learning curve, but once you’re there, you’re there! Just remember, water-based does not equal safe. Wear those respirators and nitrile gloves. The classic car guys lost lost of solvent based products a long time ago… In addition to what Gary said, a lot of grain raising can be prevented by using dewaxed shellac as a sanding sealer. -- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread... |
24 days ago |
thanks all. A lot of good tips here for using water based stuff doesn’t sound like such a mystery |
| Forum | Topics |
Woodworking Skill Share
2900 |
3919 |
256 |
943 |
222 |
Woodworking Trade & Swap
616 |
Coffee Lounge
2370 |
LumberJocks.com Site Feedback
522 |
