| Forum topic by Scotty Stepp | posted 25 days ago | 316 views | 0 times favorited | 11 replies | ![]() |
25 days ago |
Hello Woodworkers! I need a little advice. I’m in the process of designing a kitchen table for my mother and she gave me the above picture link as a possible idea. I’ve never made a table so I’m not exactly sure how I should attach the top to the base. I plan on using mortise and tenon joinery for the base. What options do I have to attach the top to the base? Wood movement is going to be an issue and I’m not sure how to approach this issue. Please feel free to recommend any reading literature that I can research for building tables! Many Thanks, |
25 days ago |
No Picture -- "Even small steps makes a distance." (Shawn Phillips, musician) |
25 days ago |
Use these table top clips If want to keep it all wood, then use wood blocks. The center one can be tight, the ones, adjacent to the center will have progressively longer oval slots to allow for the expansion of the table top. Gravity and friction will keep the top on the apron. -- Thuan |
25 days ago |
#1 watch this video -- masrol, kuala lumpur, MY. |
24 days ago |
I’ve made the long slots on the inside of the apron and used those clips before with pretty good results. I think Norm made his clips out of wood scraps, but the concept is the same. I use figure eights for smaller table tops. You don’t have to make the slot the whole length. This is especially important if that slot will show out the ends. You can use your biscuit joiner to make slots where you want them and they’ll be wide enough to accomodate the wood movement. I’m getting ready to embark on our new dining room table, so I’m right there with you. Have you thought about blogging on your progress? -- You can't control the wind, but you can trim your sails |
24 days ago |
I do the same as woodworm picture #1 using the cleats in the slot. -- Its never too late to have a happy childhood. But the second one is up to you and no one else. |
22 days ago |
I use figure 8s there simple and do the job I’ve also used clips like in picture #1 -- Jim from Heirloom Woodshop Southern Oregon |
22 days ago |
a1Jim, I’ve seen Figure 8 connectors, but until now I cannot figure out how to connect it to the appron (vertical position) and the table top (horizontal position). -- masrol, kuala lumpur, MY. |
22 days ago |
You counter sink it to the apron by the thickness and then screw to the underside of the table. -- "Even small steps makes a distance." (Shawn Phillips, musician) |
22 days ago |
Thanks notottoman, now I know, I guess. -- masrol, kuala lumpur, MY. |
22 days ago |
By George…...... I think he has it. :-) Send a photo when you done… All the best.. -- "Even small steps makes a distance." (Shawn Phillips, musician) |
20 days ago |
Thanks for all the help gentlemen. I will post my results after I get started. I’m a few weeks out at best… Notottoman, I’m also a musician…saxophone:) |
| Forum | Topics |
Woodworking Skill Share
2899 |
3917 |
256 |
942 |
221 |
Woodworking Trade & Swap
616 |
Coffee Lounge
2369 |
LumberJocks.com Site Feedback
522 |
#2
