| Forum topic by Billp | posted 30 days ago | 228 views | 0 times favorited | 5 replies | ![]() |
30 days ago |
Topic tags/keywords: question spray gun Can anyone give me some advice how to best setup a spray booth in the basement? I was wondering what types of setups you have for dust control and exhaust if you have a basement setup. I have two windows in the room I will be using. I bought a Fuji Q3 Pro, I think I will be using water based products for safety reasons. Any help will be appreciated. Thanks,Billp -- Billp |
30 days ago |
I did a little spraying in my basement shop. It has an unfinished ceiling. I used plastic painters drop “cloths” to create the booth. Stapling the plastic to the over head joist. When I was finished, just took it down and folded it up. As for ventilation, I made an exhaust fan out of an old hot air furnace blower and replaced the “fold in” basement window with the fan assembly. I open the other basement window to allow for plenty of fresh air to enter. This system has its’ dangers because if the furnace turns on while the exhaust fan is running, it can pull furnace fumes into the basement. |
30 days ago |
Nothing more to add to lew’s post. -- "Even small steps makes a distance." (Shawn Phillips, musician) |
30 days ago |
Best advise. Don’t spray in a basement, especially large items. For various reasons starting with Lew’s furnace backdraft problem, and in cold weather it will exhaust all the warm air leaving your basement cold thereby slowing the drying process and so on. Wipe on finishes are a good alternative. -- Les B, Oregon |
29 days ago |
Is there anyone out there who likes thier hvlp system and is able to use it in a basment? -- Billp |
29 days ago |
My friend and neighbor down the street, Frank, who builds lawn ornaments, built his spray booth from an old wooden bar stool with a lazy susan seat(got it at a second hand store for 5 bucks, 2 box fans (also purchased at the second hand store), two cheap blue type furnace filters and a heavy card board box. Now the box, he said, is from an appliance store and was for a 48” wide French door fridge. It is pretty big but he has the room in his basement for it. The box is open on the bottom and one side, so it has a top and three walls. On the back about a third of the way up he cut the hole Slightly smaller than one of the box fans and used wire to hang it over the opening. Inside he attached one of the filters. He had some ice and water shield he wrapped around the opening so he can duct tape the filter to it with out tearing up the card board. He painted the inside of the box white and has a 60w fluorescent bulb in a jelly jar fixture poking through the top. -- Easy Peasy Lemon Squeezy-May all your dovetails fit tight and right the first time |
| Forum | Topics |
Woodworking Skill Share
2928 |
3961 |
257 |
955 |
226 |
Woodworking Trade & Swap
622 |
Coffee Lounge
2398 |
LumberJocks.com Site Feedback
524 |
