finishing a shadowbox with trapped plexiglass
Forum topic by depictureboy posted 25 days ago 200 views 0 times favorited 6 replies Add to Favorites Watch
View depictureboy's profile
depictureboy
305 posts in 536 days
25 days ago
Topic tags/keywords: question finishing
I have a shadow box I am making that has plexiglass set in a groove along the inside, so its basically trapped by the frame. My question is how do you guys finish something like this? On my other 2 shadowboxes I did for my daughters, i glued up 3 sides, partially finished all the pieces then glued them together and put the poly on once it was assembled. I wasnt able to keep all the poly off the plexi, so i wasnt really happy with the way it turned out; though you cant really see it.
Now I am thinking that I could use painters tape along the edges of the plexi…but really I wanted to see how more experienced people did this…
I am planning on staining and then finishing with a varnish mix…
thanks all.
-- If you can't build it, code it. If you can't code it, build it. But always ALWAYS take a picture.
View DaveR's profile
DaveR
1517 posts in 613 days
25 days ago
I suppose it is too late now but I would build the frame in two parts: an inner and an outer. Then you can do the finishing work before inserting the glass or Plexiglas and it can be made so the glass can be replaced if it ever becomes damaged.
Shadow Box
Have you pulled the ‘skin’ off the Plexiglas yet?
-- Until you spread your wings, you'll have no idea how far you can walk.
View lew's profile (online now)
lew
4482 posts in 648 days
25 days ago
Looks like a job for 3M Blue Tape Man!
depictureboy
24 days ago
no I havent skinned it yet, so that is one of my options I suppose…And yes lew, I had thought about taping along the edges, I was just hoping maybe some old timer had some pearls of wisdom :)
When I was first designing it I was actually going to have the from beading be seperate from the entire case, by cutting it off the front of the sideboards then rabbet it then attach it to the front, but I got lazy…
View interpim's profile
interpim
445 posts in 351 days
24 days ago
I honestly would recommend using real glass instead of plexi. You can scrape any finish off of it with a razor blade scraper and it won’t scratch like Plexi will over time.
-- San Diego, CA US Navy
depictureboy
24 days ago
yea i thought about that too interpim…but i was concerned about breakage because of trapping it in the frame…If I was still doing the detached front, I would have done that…
16683 posts in 470 days
24 days ago
I agree with the glass idea just make sure it’s tempered glass. More costly but worth it.
