Making card scrapers from a saw plate?
« back to Hand Tools forum
Forum topic by Brett posted 08-10-2015 07:18 PM 909 views 0 times favorited 4 replies Add to Favorites Watch
View Brett's profile
Brett
660 posts in 2586 days
08-10-2015 07:18 PM
I have a Disston hand saw that was made in the 80s or early 90s. It doesn’t appear to be made of spring steel like some of the older Disstons were. Can I make a decent card scraper from the saw plate, or is the metal not suitable for a scraper?
-- More tools, fewer machines.
View Mattyboy's profile
Mattyboy
50 posts in 981 days
#1 posted 08-10-2015 09:29 PM
Brett, I’m not a steel expert, but if you can’t use the saw as a saw, then why not try it and see for yourself if it makes a good scraper. If that saw could be sharpened enough to cut wood, then maybe it can take a burr to shave tiny curls from wood.
-- Matt, Northern CA
View racerglen's profile
racerglen
3112 posts in 2683 days
#2 posted 08-10-2015 10:59 PM
Brett it works very well, steel’s just fine.
-- Glen, B.C. Canada
View Tim's profile
Tim
3727 posts in 1864 days
#3 posted 08-10-2015 11:25 PM
I don’t know about the newer steel but I will say that pitted saw plates are not ideal for scrapers. The pits keep you from getting a perfect even hook. Can still work decent, but it’s a lot of work to get the pits out. It’s better if you have a saw that’s not so pitted to cut up. Also cutting with a hacksaw is the best method to cut the plate up I’ve found so far. Doesn’t ruin the temper and doesn’t warp the metal as much as shears do. I use a hacksaw blade in a saws all.
View canadianchips's profile
canadianchips
2600 posts in 2900 days
#4 posted 08-10-2015 11:44 PM
I ve made them from old saws. Mine worked well. Took time to polished edge before sharpening, and pitting was gone.When i cut mine i had bucket of water beside to keep the metal cool ALWAYS.
You are nothing out if yours doesnt work. Maybe good practice as well.
