R4510 Tablesaw and 8" Dado blade.
Forum topic by misterbig posted 08-09-2015 10:39 PM 709 views 0 times favorited 3 replies Add to Favorites Watch
View misterbig's profile
misterbig
45 posts in 1642 days
08-09-2015 10:39 PM
I just found a steal of a deal today at a garage sale a brand new Freud 8” dado set for $10.00. The people selling it said that they found it in the garage shelving when they bought their house. I was so excited as I was wanting to purchase one for the longest time. Reading the manual that came with the saw it said that it will only accept a 6” dado. The blade fits as I put it on just haven’t fired it up. Anyone out there using a 8” dado on this saw?
Why would they say only six inch? The only reason that I can think of is if the riving knife lock is in the down position it will hit. But since you don’t use a riving knife then leaving it up in the open position is fine.
What is your thoughts?
M
3 replies so far
View TarHeelz's profile
TarHeelz
59 posts in 2045 days
#1 posted 08-09-2015 10:46 PM
8” creates more rotational torque than the saw can handle. You risk screwing up the arbor on your saw.
If you have a local woodworking club, I’m guessing you’ll find someone to trade with you in no time at all.
-- Tar Heelz, Durham, NC USA
View MrUnix's profile
MrUnix
6586 posts in 2163 days
#2 posted 08-09-2015 10:54 PM
You have a direct drive universal motor in that saw, which is not designed to handle larger blades. You can probably get away with using it for a limited time, but eventually, it will tear up your motor.
View crank49's profile
crank49
4030 posts in 2935 days
#3 posted 08-10-2015 01:46 AM
Don’t those universal motor saws run at a higher RPM than induction motor saws.
That would be a major reason to limit the diameter.
Still comes down to the potential torque load of course because the dado blade is heavier than a normal blade.
