| Forum topic by LesB | posted 29 days ago | 266 views | 0 times favorited | 9 replies | ![]() |
29 days ago |
Has anyone ever tried adding color to super glue (cyanoacrylate)???? Like many turners I often use it (the thick kind) to fill cracks or secure knots in wood turning projects and it would be great if I could color it or buy some already colored. I’m not even sure what color agents would work. Black or dark brown would be a great start. I did a quick web search and did not come up with anything that seemed to apply here. I have used colored epoxy but often the cracks to be filled are not big enough to work the thick epoxy into. -- Les B, Oregon |
29 days ago |
I use crushed stone and other crushed items to mix in CA for coloration and fill all the time. I also used some analine in CA to fill a crack on a piece that someone had purchased at a craft show that probably was not completely dry when they put finish on it…the analine tinted the CA so that it appeared as part of the grain…I don’t see why you could not add any other types of tint…just remember that the CA will set up fast and you don’t get alot of time to mix and apply it. -- Woodworking.....My small slice of heaven! |
28 days ago |
LesB I also use CA when turning but only the one that seems thinner than water to fill cracks. 1. Fill crack with sanding dust of item being turned and then add a drop or 2 CA1. 2. The crack will be a shade darker than the wood around it but as u are turning th piece a final light cut will remove a bit and it wil not be as pormiment. 3. To prevent surronding wood being tainted apply a coat of sanding sealer celulose type. 4. Remember if wood is bone dry CA takes a long time to dry it likes a bit of moisture. If noty Clear drop me a pm and I will try and help where I can. Kind Regards Roger South Africa -- Always give it your best shot |
28 days ago |
Would you have enough time to mix the color in before it sets? Wont the tint act as an accelerator? If someone is doing it let us know how and what you are using that wont make it set. Sometimes my CA sets before I can get my fingers away from it. -- Ray Cody, Florence Alabama |
28 days ago |
DO NOT USE DYE TO TINT CA GLUE! I added a couple drops of Transtint Dye to a small remainder of CA glue in the bottle and it caused a heated reaction that nearly burnt my hand and it melted the bottle – REALLY melted it! The reaction generated so much heat that it caused the bottle to smoke although it never actually combusted. You would think that I would be an idiot to burn my hand but I kept using it as long as possible before it was rendered useless or too hot. -- Todd A. Clippinger, Montana, http://amcraftsman.com |
28 days ago |
What kind of base is the transtint? I wonder what ingredient caused that? I’ve put analine powder in CA without that kind of reaction…but I sure don’t want to take a chance of that happening….thanks for the warning. -- Woodworking.....My small slice of heaven! |
28 days ago |
CA glue dries by moisture, I would think water would be the reactor. Alcohol has some water in it. So what Todd experienced was probably caused by it drying. -- What happens in the workshop stays in the workshop. No wait that doesn't sound right. Karson Southern Delaware karson_morrison@bigfoot.com † |
28 days ago |
This is the best “super glue” on the market: They have a black super glue, and they offer the clear stuff in super thin—like water—that is the definitive glue to use when executing the sawdust/superglue fill technique. This is what the luthiers (guitarmakers) use, along with sawdust, to fill gaps so they can produce instruments with a super-smooth, flawless surface. Hope this helps. -- Autumn |
28 days ago |
Thanks for the responses. The black glue from Starbond sounds interesting. -- Les B, Oregon |
27 days ago |
I tried that once, the results were not what you would call “positive.” Henry Jones II |
| Forum | Topics |
Woodworking Skill Share
2917 |
3944 |
256 |
950 |
224 |
Woodworking Trade & Swap
619 |
Coffee Lounge
2390 |
LumberJocks.com Site Feedback
524 |
