Another Router Bit question...this time about spiral bits.
Forum topic by SteveC3606 posted 32 days ago 190 views 0 times favorited 5 replies Add to Favorites Watch
Rockler
View SteveC3606's profile
SteveC3606
8 posts in 43 days
32 days ago
Topic tags/keywords: router bits spiral bits router
When should I think about using an upspiral bit? a downspiral bit? can these bits be used with a guide bushing?
-- Stevec3606
17211 posts in 477 days
32 days ago
Spiral bits are great the direction has to do with which way you want the chips to go . Yes the can be used with a guide bushing. You can use them any time you would be using a straight bit they are great bits and usually reduce the amount of tear out you get.
SteveC3606
8 posts in 43 days
32 days ago
Thanks Jim.
-- Stevec3606
View LesB's profile
LesB
555 posts in 343 days
32 days ago
One of the main differences in up and down is the way it affects the edges of the cut. Up spiral will lift the fibers along the edge sometimes leaving them rough. Down will shear the fibers in a downward cut leaving a cleaner cut. The up spiral tends to pull the bit down and visa versa for the down spiral.
There are spiral bits that have a combination with the first portion being up and the upper part being down giving the best of both functions. I haven’t tried them but the idea looks good, except they are more expensive.
I don’t see any problem using a guide bushing with spiral bits. I do it all the time.
-- Les B, Oregon
32 days ago
A much better explanation of spiral bits Les well done
View reggiek's profile
reggiek
719 posts in 170 days
32 days ago
Also, it depends on what face you are cutting on….the up spiral with make the bottom side clean cut…whereas the down will do the opposite. You also want to use a down spiral when cutting a grove in the face of the wood as it will leave the open edges cleaner….I have both and use them alot….I use them with guide bearings and without..with no problems….they are just as good as bearing guided trim bits…but of course more expensive.
