Lathe Chucks - what should I look for?
Forum topic by snowdog posted 782 days ago 374 views 0 times favorited 5 replies Add to Favorites Watch
View snowdog's profile
snowdog
808 posts in 878 days
782 days ago
Topic tags/keywords: chuck lathe
What should I be looking for in a chuck. What do you guys use?
I have an JML-1014IVS: 10”x14” Variable Speed Mini Lathe with Indexing Head and a few chisels. I was looking at Chucks. WOW! are there a lot. I am not sure where to begin.
Here are two I looked at.
PSI Woodworking CSC3000C Barracuda Wood Lathe Key Chuck System
http://store.lumberjocks.com/shop.php?c=accessories&n=552512&i=B000KIACTG&x=PSI_Woodworking_CSC3000C_Barracuda_Wood_Lathe_Key_Chuck_System
Nova G3 Chuck
http://www.woodcraft.com/family.aspx?FamilyID=5766
NOVA G3 With 1”- 8 Insert Kit?
NOVA G3 Chuck With 3/4”- 16 Insert Kit?
NOVA G3 Chuck 1-1/4”- 8 Insert Kit?
I am not really sure what the different sizes (1’-8, etc) really refer to.
View WayneC's profile
WayneC
6012 posts in 993 days
782 days ago
You have to match the chuck to your lathe’s spindle size. I belive your Jet is 1” diameter spindle 8 threads per inch TPI….
The Nova would be a nice chuck…
View mike's profile
mike
46 posts in 1206 days
750 days ago
Let’s see – I have the Rikon Mini/Midi Lathe and bowl turning in an important part of what I do. That said budget is everything because it isn’t just the chuck its the extra jaws, the Cole jaw set, the spur insert .. ....
I decided on the Pinnacle chuck system sold by Woodcraft. So far I am happy with my choice and it has done everything I needed it to do and has a full range of accessories. As with most chuck systems it has a threaded insert that you match to your headstock spindle so if you work on more than one lathe you only need the proper insert.
Oh I should also mention that I will probably buy a second check early next year – lathe tools are like potato chips never can stop with one. Not sure if I will buy a second Pinnacle or go with a Nova but then there are those darn accessories.
Cheers
Mike
-- Mike, Maryland, www.thewoodenquill.com
View mot's profile
mot
4903 posts in 932 days
750 days ago
I think that Nova G3 is a very worthy chuck. I use Nova chucks and really like them. The G3 replaced their Midi line and the G3 is a better system. You just get the size to match your spindle, as Wayne said. The nice thing about the Nova chuck is that it uses spindle inserts. So if you buy another lathe you can just change the inserts in your chuck…if that lathe has a different spindle. Your lathe has a 1”x 8 TPI spindle.
Cheers!
View Dorje's profile
Dorje
1767 posts in 893 days
750 days ago
I have a couple of the Oneway chucks, and a couple jaw sets – very well made. I’ve heard good things about the Nova (Teknatool’s) chucks too.
If you started with the Pinnacle, you may want to stick with it – especially if the parts are interchangeable, which it sounds like was a concern…
Douglas Bordner
3424 posts in 959 days
750 days ago
I have the Nova G3 as well. Nothing but good things to say about it. I have a Jet Mini lathe, it does have a 1˝- 8 TPI spindle.
