| Forum topic by dlmckirdy | posted 33 days ago | 277 views | 0 times favorited | 10 replies | ![]() |
33 days ago |
Topic tags/keywords: sketchup I am modeling a cabinet door with recessed roundovers on the stiles and coves on the rails. the outer edges of the stiles and rails are also rounded over. Sketchup will not allow a curved face to be extruded through another curved face, resulting in some funky looking joinery. I can do a workaround to render the finished product to look good, but it does not reflect the actual shapes of the parts. Any help or suggestions would be appreciated. -- Doug, Bakersfield, CA - I measured twice, cut it twice, and it is still too short! |
33 days ago |
Doug, I am sure that DaveR will chime in on this. He is the resident Sketchup expert on board here. -- With God's help all things are possible- even woodworking. Woodworking is not just a hobby, it is an (expletive deleted) expensive hobby. |
33 days ago |
Doug, Scott was right. I will chime in. I’m not sure that I’m the resident expert but I’ll try to help. Are you referring to drawing the cope and stick profiles on the ends of the rails? If you can give me a little more detail, I’ll show you how to do what you’re after. Thank you Scott. Dave -- Until you spread your wings, you'll have no idea how far you can walk. |
33 days ago |
Doug, I will be interested in seeing Dave’s response to this. It sounds like you are having a problem that I do as well. Trying to put a round over, for instance, on mitered joints just does not work with the push/pull tool. Just guessing I would say it probably involves using the follow me tool but I am still trying to get familiar with that function. -- With God's help all things are possible- even woodworking. Woodworking is not just a hobby, it is an (expletive deleted) expensive hobby. |
33 days ago |
32 days ago |
Daver, Yes, that is exactly what I am trying to do. -- Doug, Bakersfield, CA - I measured twice, cut it twice, and it is still too short! |
32 days ago |
Ok. you can’t do that in SketchUp. Just kidding. I’ll make up the steps for you and post it in a little while. -- Until you spread your wings, you'll have no idea how far you can walk. |
32 days ago |
No doubt in my mind Dave you are the resident expert. Great job what you can do with sketchup always amazes me. -- Jim from Heirloom Woodshop, custom furniture ,maker, woodworking school, heirloomwoodshop.com |
32 days ago |
Thanks Jim, SO here we go Doug.
Now to profile the outside edge of the stile.
Now, I bet you’re wondering what to do with the opposite ends. You could repeat the first part of this on the opposite end of the rail. There’s another and I think easier way. Draw the rails and stiles to half their final length when you start. After you’ve finished the above, open each component in turn, select all of its geometry and copy it with Ctrl+Move. Drag the copy away. Horizontally in the case of the rail and vertically in the case of the stile. With the copy selected, right click and choose Flip Along and flip that geometry to mirror it end for end. In my example here, that would be along the red direction for the rail and blue for the stile. Then move the copy so the flat end meets the flat end of the original. Delete the ‘seam line’ around the middle of the part and you’re finished. Certainly once you’ve drawn the entire thing, there’s no reason to ever draw that same profile again. You can simply resize the existing components to fit any door size with the Move tool. Howzzat, Doug? -- Until you spread your wings, you'll have no idea how far you can walk. |
32 days ago |
Looks Great! Easy, too! I’ll give it a try, and let you know how it works out. How do you insert the illustrations into this thread? -- Doug, Bakersfield, CA - I measured twice, cut it twice, and it is still too short! |
32 days ago |
Glad that seems to work. I put the illustrations into my Flickr album and then copied the HTML code for each image and pasted it into my reply. If you click on the images you can get a larger version if you want. FWIW, there’s a slightly easier method but this was easier to show in still images. -- Until you spread your wings, you'll have no idea how far you can walk. |
| Forum | Topics |
Woodworking Skill Share
2937 |
3969 |
260 |
956 |
226 |
Woodworking Trade & Swap
624 |
Coffee Lounge
2404 |
LumberJocks.com Site Feedback
525 |
