| Forum topic by Vern Little | posted 29 days ago | 286 views | 0 times favorited | 13 replies | ![]() |
29 days ago |
Topic tags/keywords: dust collector |
29 days ago |
I have three all HF rated at 2hp and 1700 cfm I doubt both but they work fine and they were all under $ 150 each , two are set up out side and one inside. when I built my shop I put long trenches in my concrete with metal covers for dust collection,wireing and air. One out side DC is just for my Table saw another outside one takes care of a number tools like my planner,sander, moulder and other misl tools. and the last on is just for my jointer. I use 4” pvc ducts on all of it. -- Jim from Heirloom Woodshop Southern Oregon |
29 days ago |
Vern, I have a 1 3/4 HP collector. It has two inlets that I am running 4” hoses to the tools. One line I have attached to a cyclone lid separator and 30 gallon trash can. This line I hook up to my planer/jointer/bandsaw. The other line I leave attached to my table saw. Right now I am treating it as a portable collector and may plumb it in later but my shop configuration may be a challenge to do this. -- With God's help all things are possible- even woodworking. Woodworking is not just a hobby, it is an (expletive deleted) expensive hobby. |
29 days ago |
Hi Vern, I have a 2hp Grizzly that is about 8 years old. I am running 4” hose and us a Long Ranger 220v remote. My system is outside under a shed roof beside my shop. I had a broken window so I replaced it with a piece of plywood and ran the 4” hose and wiring through it. -- Dan-- Info for all @ http://www.hoistman.com |
29 days ago |
I have a 1.5hp Penn State. I got it only a few weeks ago, so my only hookups from the outlets are one 4” to my TS and the other a 2.5’ to my crosscut RAS. With only those two connections I don’t need any blast gates at this point. At this point and with my shop configuration, I am not planning on plumbing in piping, but will put my other and future machines on castors and roll them where I can attach a third hose when needed, at that point I will probably need to add blast gates. |
28 days ago |
Thanks for the feedback. I was looking at a Jet 1-1/2 HP someone has on Craigs list for $250.It is suposed to be new. |
28 days ago |
I have a 2HP Grizzly that I added a cyclone in the input hose and I removed the bags and installed a paper filter from a Grizzly DC and a plastic bag for the bottom. Really works great now. -- What happens in the workshop stays in the workshop. No wait that doesn't sound right. Karson Southern Delaware karson_morrison@bigfoot.com † |
28 days ago |
Onieda 5 HP tower with twin 55 gallon drums. Not expensive, but the cost of additional metal ducting has been terrible over the last two years. For a home shop look into a portable collector without all the tubing - |
28 days ago |
Karson, If you still have half of the wood as is in the pictures of you shop, It could outlast your grand children. Vern |
28 days ago |
I have a Powermatic 1 3/4 hp PM1300 with the canister. Its rated at 1064 CFM. My shop isnt real big (450 sq ft) and I have it hooked to 4” plastic flex pipe. I dont use a separator. I have runs to my drill press, jointer, radial arm saw, table saw, planer, and band saw. I also have a sweep that I can sweep the floor into. -- Wayne - Plymouth MN |
26 days ago |
I have a 1.5 hp General International DC. General International is a Canadian company and only ships in Canada. They are pretty much the same as Grizzly because their tools all look and sound the same. -- Remember, measure twice, cut once |
26 days ago |
Vern, Dustmite, -- A hammer dangling from a wall will bang and sound like work when the wind blows the right way. |
26 days ago |
I don’t like to brag, but my girl thinks the bags are pretty big….. I tell her that’s normal for Powermatic 1900’s (3hp) |
26 days ago |
2hp Central, 1550 CFM, Dual intake, cyclone seperator, 30gal Gcan, Combination 4” metal duct and 4” hoses, Couple of blast gates, adapters and pickups. Use the on the router, table saw jointer, planer and drill press. Oops, band saw and RAS too. Got to get a floor scoop though, still use way too much Armstrong and push broom. LOL :>) -- Easy Peasy Lemon Squeezy-May all your dovetails fit tight and right the first time |
| Forum | Topics |
Woodworking Skill Share
2912 |
3939 |
256 |
948 |
223 |
Woodworking Trade & Swap
619 |
Coffee Lounge
2383 |
LumberJocks.com Site Feedback
523 |
