Sag in a butcher block?
Forum topic by Weatherman posted 08-08-2015 07:50 PM 1322 views 0 times favorited 5 replies Add to Favorites Watch
View Weatherman's profile
Weatherman
18 posts in 2571 days
08-08-2015 07:50 PM
Topic tags/keywords: butcher block end grain maple cutting board
Hi all,
I received an inquiry from a friend for a project for his mom’s kitchen. Basically she wants a large maple, end grain butcher block to cover a glass stove top that is recessed into the kitchen counters. The requested dimensions are roughly 2” x 25” x 37”. The purpose is to have the block sit across the range that is 24” x 36”. There would be about half an inch clearance between the bottom of the butcher block and the glass stove top.
I’ve never built a block this big before. It should weigh about 75lbs or so. at 2” thick, do you think there would be any sag that I would have to worry about across the middle? I think I would rather have the ends extend further onto the counter top for more stability.
Thanks!
Brian
-- Brian
5 replies so far
View 01ntrain's profile
01ntrain
257 posts in 1189 days
#1 posted 08-08-2015 08:03 PM
I like your thinking about a bit more support…..perhaps 26×38? As far as sag goes….if glued up properly, you really shouldn’t have any. Not at 2” thick. You might consider biscuits in your glue-ups if that worries you at all.
View TheFridge's profile
TheFridge
10113 posts in 1605 days
#2 posted 08-08-2015 08:05 PM
pretty sure you should have any probs whatsoever. I made a 2 1/2” x 24” x 48” laminated workbench top that I’ve had zero problems with even throughout many days of 90-100 deg heat in my shop.
Weatherman
#3 posted 08-08-2015 10:48 PM
Thanks guys. I’ll have to do the glue up in smaller sections. I planned on using biscuits to help align the larger sections for glue up once they’re ready. Heat index in Texas is at 110 and I work out of my garage. Even with Titebond 3 I won’t have much working time.
-- Brian
View rwe2156's profile
rwe2156
3069 posts in 1600 days
#4 posted 08-08-2015 11:39 PM
Can it be in 2 pieces?
What the purpose in putting on top of stove. Just curious.
View ddockstader's profile
ddockstader
157 posts in 3381 days
#5 posted 08-19-2015 05:07 AM
My greater concern would be that those lovely, glass-topped range are very difficult to determine if you have turned them OFF! For some of them the only indication is a small red light in the center of each burner, a light that would be completely invisible under this butcher block. I think you’ve got a really great chance of not only warping the butcher block, but possibly setting it on fire. Certainly the glue joints may crack if heated inadvertently.
