| Forum topic by frostwood | posted 28 days ago | 217 views | 0 times favorited | 8 replies | ![]() |
28 days ago |
Even when removing the washer I can only fit up to 5/8 inch. I am noticing that most table saws come with a 5/8 arbor. Does the 5/8 arbor size indicate the dado capable width or is this the diameter size ? -- With each new day, celebrate life. Love God with all of your heart. Share Jesus with those around you and make a positive impact on those you meet. Bob |
28 days ago |
5/8” typically is the diameter of the arbor. -- I can fix ANYTHING!.... Wheres the duct tape? |
27 days ago |
What saw do you have Bob? |
27 days ago |
Is this a benchtop saw? If so, it can probably only take 1/2” of a stacked dado by design. Quite often, these saws are direct drive or have a motor that is too small to handle the load of a wider/heavier dado set so the manufacturer intentionally provides a shorter arbor. -- The only place success comes before work is in the dictionary. -- Vincent T. Lombardi |
27 days ago |
the arbor diameter is 5/8” which is common on most 10” saws. the max width of dado one can fit on the arbor varies between saws, and is usually stated on the specs of the saw. this depends on the LENGTH of the arbor, and not on it’s diameter. -- When in doubt - There is no doubt - Go the safer route. |
27 days ago |
I faught with that problem for years with my old saw, the only solution I could come up with was a new bigger, meaner saw. -- Dave- New Brunswick |
27 days ago |
Depending on your saw it is possible that you are not supposed to put a dado on it. My old mastercraft maximum did take a dado but max 6” blade with a max 1/2” stack. My buddies mastercraft (not labeled maximum but looks almost exactly the same) is not designed to take one although it has the same size arbor. I don’t have the saw anymore se we could not compare motor specs. Best thing is check the manual, if you don’t have that, I would not go over 1/2” just for safety reasons. -- If all you have is a hammer, everything looks like a nail! |
27 days ago |
Thanks, everyone. Though I didn’t ask the question, dados were on my mind. I didn’t check any specs because I can’t afford a true shop saw yet, however, I do have a set of chippers (which I never used). -- Wish I were Norm's Nephew |
26 days ago |
I have a craftsman 137.248880. I did find in the manuel where it shows a 1/2 ” dado on the spec sheet. I did remove the washer and fit a5/8 ” which I used on a sacrificial fence to cut a bout a 1/2 ’ dado for a toung and dado drawer . -- With each new day, celebrate life. Love God with all of your heart. Share Jesus with those around you and make a positive impact on those you meet. Bob |
| Forum | Topics |
Woodworking Skill Share
2909 |
3934 |
256 |
946 |
223 |
Woodworking Trade & Swap
617 |
Coffee Lounge
2378 |
LumberJocks.com Site Feedback
522 |
