| Forum topic by sikrap | posted 29 days ago | 235 views | 0 times favorited | 10 replies | ![]() |
29 days ago |
I was able to get some elm cut up from a tree that had fallen in my yard. I have some beautiful slabs that are 2” thick and my question is this: can I use pine for stickers? I thought I had heard that stickers had to be hardwood (no oak), but the guy that sawed the log said there is no problem using pine ( I have a lot of leftover 2×4s from the garage). Thanks for the help!! -- Dave, Colonie, NY |
29 days ago |
They are fine. Make sure that the stickers are absolutely dry. |
29 days ago |
I dried a bunch of elm last winter using white oak stickers and had no problem. I would assume you’ll be fine with pine stickers. Check out my blogs to see the material that I got out of a nice American elm. -- Julian, Park Forest, IL |
29 days ago |
I use pine and douglas fir and have never had a stain problem. -- Doug, Cass City, Michigan |
29 days ago |
I rip 2×10’s into 3/4 sq they have worked well for Cherry, Maple, Hickory, Locust, Walnut, Red and White Oak. Make sure that they are stacked neatly to stabilize your stack (I stack up to 6ft) and prevent warpage. -- Dane, Fairview Pk, OH. The large print giveth and the small print taketh away... |
29 days ago |
The pine should work fine as long as they are reasonably dry, space them out evenly at about 18” -- Phil |
29 days ago |
Available pine, fir, no problem but if you find ‘em or buy ‘em, they must be aged, true dry. |
29 days ago |
Thanks to all for the prompt and helpful responses. I’m pretty sure the 2×4s I used a dry. I may go out and buy some hardwood stickers from a local sawmill just to save some space. Then all I need to do is sit back and wait 2 years for it to dry. Julian, the computer desk you made from elm looked very nice. Are there any pictures of the finished product? -- Dave, Colonie, NY |
29 days ago |
Life has thrown me for a loop this year and I haven’t been able to finish the desk yet. I will post more on it when I do get around to it though. -- Julian, Park Forest, IL |
29 days ago |
Okay, thanks. You had offered me some advice earlier on this wood and suggested that I have it cut to 1 1/4”, but the sawyer said I would have less warpage at 2” and that is what he cut the stuff he kept at. Do you think this will pose any problems (other than taking forever to dry)? -- Dave, Colonie, NY |
29 days ago |
The only problem with 2” lumber is you’ll find it hard to get two 3/4” thick pieces out of it after it’s dry. The pieces I had milled at 1 1/8” work out to 3/4”-13/16” thick after plaining it down due to the fact that it shrank so much during drying. As far as warping goes, I had virtually none in any of the boards I have and they are all around 16”-20” wide. I attribute this to the fact that the lumber dried slowly over the winter in my solar kiln. -- Julian, Park Forest, IL |
| Forum | Topics |
Woodworking Skill Share
2912 |
3939 |
256 |
948 |
223 |
Woodworking Trade & Swap
619 |
Coffee Lounge
2383 |
LumberJocks.com Site Feedback
523 |
