power motor for router lift
Forum topic by psient posted 08-07-2015 12:07 PM 895 views 0 times favorited 5 replies Add to Favorites Watch
View psient's profile
psient
82 posts in 2278 days
08-07-2015 12:07 PM
Hello all:
I have been designing a table for my router. The router is a Milwaukee 5625. The lift will be Jessem’s Mast r lift II. I need the table for bits that can only be used in a table mounted router (i.e., drawer lock joint).
In researching table designs, I found a you tube video with a fellow using a power window motor. Since the motor is made to work a heavy load in short bursts the application seemed safe and appropriate. Has anyone designed and built their own motorization of actuating their router while mounted in a commercially available lift?
Specifically, how does one go about engineering the motorization electronics and sizing the transformer? The mechanical linkage shouldn’t be a problem as I have a garage machine shop; Bridgeport Mill and a 13X40 engine lathe, and lots of tooling. The gent in the video used a universal-joint/swivel socket adapter to solve the motor-to-lift shaft placement/alignment problem.
5 replies so far
View exelectrician's profile
exelectrician
2327 posts in 2392 days
#1 posted 08-07-2015 04:47 PM
Use a reversible electric screwdriver, all the hex drive stuff is already built in all you have to do is rig a remote extension of the switch …
-- Love thy neighbour as thyself
View rwe2156's profile
rwe2156
2881 posts in 1445 days
#2 posted 08-08-2015 12:23 AM
The guy on Eagle Lake ww’ing has something about a homemade power lift.
View bonesbr549's profile
bonesbr549
1531 posts in 3031 days
#3 posted 08-08-2015 02:13 AM
I use a hex key in a drill works great.
View Redoak49's profile
Redoak49
3195 posts in 1953 days
#4 posted 08-08-2015 11:01 AM
I also use an battery driver. However, I use the hand crank for final adjustments. Sometimes a few thousandths makes a difference and hard to get with a power driver.
View Holbs's profile
Holbs
1841 posts in 1994 days
#5 posted 08-08-2015 04:55 PM
when it comes time to tackle my router cabinet, I’ll go the simple route of raising and lowering the router quickly and accurately. Quick Action Lever Router Lift
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
