Router speed advice
Forum topic by bhacksaw posted 08-07-2015 04:35 AM 847 views 0 times favorited 5 replies Add to Favorites Watch
View bhacksaw's profile
bhacksaw
162 posts in 1699 days
08-07-2015 04:35 AM
I have a second hand Porter Cable single speed router that I have under mounted to a router table I built two years ago and it works great. I bought a raised panel bit and just now looked at the router speed chart that’s been on the table since I built it. First thing I noticed is that it recommends 17000rpm (going from memory on this) for regular but sizes (1/4” straight bit) then I read that my router runs at 22000 rpm. Is that ok? Next, I saw that I should be running it at 12000 for this panel bit due to its size. Do those variable speed controls work on single speed routers? Forgive my ignorance, I don’t know where to read up on them. If not, do i really need to spend $200-300 on a variable speed if it’s a mounted router?
5 replies so far
View MrUnix's profile
MrUnix
6199 posts in 2074 days
#1 posted 08-07-2015 04:43 AM
22,000-24,000 rpm is fine for anything up to about an inch. If the manufacturer of your panel bit recommends 12,000, then that is probably about as fast as you should go. Most brush type motors can be used with a speed control AFAIK, and I know several people who use the HF one (<$20) without any problem.
View rg33's profile
rg33
83 posts in 1877 days
#2 posted 08-07-2015 06:12 AM
+1 vote for the HF speed control Brad recommended. I may have the same setup as you. A 690 porter cable but mine is hooked up to the HF speed control. I then dial the speed accordingly. Usually the larger the bit the slower you need to go; think about it, as the diameter of the bit gets larger for the same RPM its actually traveling a lot faster. Do a google search and you will find recommended speeds. However this wont help with your or my setup as the speed control doesnt actually give an rpm reading. What I do is usually run a scrap piece of wood. I start slow and if it bogs down a little too much I dial it up, burning and you’ve sped up too much. Also some woods are more forgiving than others.
To answer your question about the speed control, as long as your router doesnt have a “soft start” then the speed control should work fine
bhacksaw
#3 posted 08-07-2015 04:48 PM
Great advice, guys. Thanks. Good to know the HF one works well.
View timbertailor's profile
timbertailor
1594 posts in 1299 days
#4 posted 08-08-2015 04:42 PM
ALWAYS FOLLOW THE SPEED RECOMMENDATIONS OF THE MANUFACTURER FOR THE BIT USED. Especially with larger bits.
timbertailor
#5 posted 08-08-2015 06:44 PM
Helpfull information…
thank you :)
- PricillaBannet
You have been busy!!!
