Drawer bottoms
Forum topic by jd3020 posted 10-27-2009 05:20 AM 1150 views 0 times favorited 5 replies Add to Favorites Watch
View jd3020's profile
13 posts in 3068 days
10-27-2009 05:20 AM
I want to build a bowed front hall table and was wondering what I should use in the bottom of the drawer. In the past I have used lauan ply or hardboard. But on a piece of furniture that I want to last for a long time, what should I use? David
5 replies so far
View Kjuly's profile
308 posts in 3217 days
#1 posted 10-27-2009 01:02 PM
Hi David,
I suggest using plywood of the same species that the table was built from.
Many of the lumber dealers will sell a 1/2 or 1/4 sheet of plywood.
It sounds like a nice table…please post pictures when it finished.
-- Keith, Charlotte, MI
27251 posts in 3753 days
#2 posted 10-27-2009 01:15 PM
David, I am with Keith on this. I generally make my drawer components out of 1/2” maple and use either 1/4 or 1/2 inch birch or maple plywood for the drawer bottoms depending on strength that I think I am going to need in the drawer.
View Roz's profile
1699 posts in 3717 days
#3 posted 10-27-2009 07:59 PM
David, I have a little different take on this. I have repaired and refinished many well built pieces of antique furniture and in almost every case the craftsmen used a secondary wood like yellow pine for dust panels and drawers. I have used Cherry and Walnut to make drawer sides, backs and bottoms, but feel it is a waist of material.
We have a good source of quality yellow pine here and that is what I use most often for drawers with a 1/4 inch A/C or a hand selected piece of luan for a bottom. These materials are is strong and durable and do not detract form the quality of the project. I hand select the pine and plywood I am going to use.
I have also made drawer bottoms for dimensional lumber. It required more time and the result was no real improvement over plywood, because of the plywood’s improved stability and strength.
-- Terry Roswell, L.A. (Lower Alabama) "Life is what happens to you when you are making other plans."
View SnowyRiver's profile
51457 posts in 3411 days
#4 posted 10-27-2009 09:20 PM
I tend to use hardboard if the drawer is small. Otherwise plywood makes a great bottom. If its the bottom of a trunk or cabinet that requires some strenght then I often use poplar.
-- Wayne - Plymouth MN
117029 posts in 3508 days
#5 posted 10-29-2009 03:33 AM
Unless your doing antique restoration I would use plywood also it’s much more stable and has allot less movement than solid wood.
-- wood crafting & classes
