What type of joints - mobile base for my saw
Forum topic by lepelerin posted 08-05-2015 12:30 AM 707 views 0 times favorited 5 replies Add to Favorites Watch
View lepelerin's profile
lepelerin
495 posts in 2289 days
08-05-2015 12:30 AM
Topic tags/keywords: tip question trick mobile base saw delta 36-714
Hi,
I recently acquired a Delta 36-714 that I am slowly cleaning and tuning up.
I had to disassemble the saw in order to put it in my car.
and some rust on the wings
and some dust
this is where I am at.
I will make my own mobile base based on an idea from LJ Yostriker (http://lumberjocks.com/Yostriker/blog/27204#comment-2504762 )
If I want to make a base like that
What type of joints do I use to make that base solid.
Do you screw the longer 2×4 on the end of the shorter one and glue?
How would you do it?
For the part supporting the casters, do you just screw on the edge of the 2×4 and glue? Do you bolt it for more strength.
I have a couple of 2×4 that I plan to use for the base, I need to keep it as inexpensive as possible.
I want to make it right the first time and for that I need your help.
Thank you very much in advance,
Arnaud
5 replies so far
View gfadvm's profile
gfadvm
14940 posts in 2655 days
#1 posted 08-05-2015 01:07 AM
2×6s with half lap joints in the corners. Screw the casters to the bottom of the corners. I have these under my planers and drum sanders as well as my radial arm saw.
lepelerin
#2 posted 08-05-2015 01:31 AM
oops I put 2×6 but it’s 2×4 that I have. So half lap on 2×4?
gfadvm
#3 posted 08-05-2015 01:37 AM
That should work if you pick decent 2×4s with no big knots. I used 2×4s under a 5 hp/18” planer and it’s holding up.
lepelerin
#4 posted 08-05-2015 08:21 PM
Tx gfadvm.
I cannot believe that only 1 LJ had an answer to my question! Surprising …
View DrDirt's profile
DrDirt
4423 posts in 3707 days
#5 posted 08-05-2015 09:30 PM
I would do half-inch finger joints at the corners -—4 fingers on one board… 3 on the other for 2X material…
Although with the casters mounted onto that cross member… the “box frame” around the base of the machine doesn’t have much stress on it.
