What to do with this Burl?<
« back to Woodturning forum
Forum topic by ormonddab posted 08-04-2015 11:31 PM 1220 views 0 times favorited 9 replies Add to Favorites Watch
View ormonddab's profile
ormonddab
10 posts in 2118 days
08-04-2015 11:31 PM
Topic tags/keywords: woodturning burl oak hollow form turning
This is my first post here.
I have been woodturning for about 2 years and have really enjoyed it.
A friend brought me this burl that he cut, from an oak I believe. I’ve had it for about a year and I’m now ready to do something with it. I’ve turned 15 or more bowls and a couple of hollow forms, a set of legs for a bath table and about 5 Peppermillls, but no burls yet.
Are there any recommendations on how to begin? The Burl is about 10” in diameter.
Should I try to cut it in half to see what it looks like inside, or try to mount it between centers and try to do a hollow form?
Any ideas on what the next step should be would be appreciated.
Thanks, ormonddmd
9 replies so far
View mahdee's profile
mahdee
3888 posts in 1790 days
#1 posted 08-04-2015 11:57 PM
If it is 10” in diameter, by cutting it in half, you are lucky to get two 4” bowl out of it. One big bowl would look really nice. Not sure what a lamp post would look like. Just a few ideas.
-- earthartandfoods.com
View LeeMills's profile
LeeMills
549 posts in 1324 days
#2 posted 08-05-2015 01:09 AM
You will have to decide whether to go bowl or hollow form.
If bowl then I would split just like a log (lengthwise along the pith) giving you two 10” diameter blanks.
I would be tempted to go bowls and turn one base out (bark outside like most bowls) and one center base giving a natural edge bowl.
View JollyGreen67's profile
JollyGreen67
1676 posts in 2785 days
#3 posted 08-05-2015 01:50 AM
Send it to me – I’ll figure something out. ;o)
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected !
View DaveDelo's profile
DaveDelo
86 posts in 2917 days
#4 posted 08-05-2015 02:29 AM
I did one of these branch burls a couple months ago. Cut off the extra off each end and put it between centers to see what was underneath. Think mine was a little bit longer than yours so it made a nice little bowling ball pin shaped vase. This was a cherry burl piece and turned out half decent.
View Wildwood's profile
Wildwood
2322 posts in 2157 days
#5 posted 08-05-2015 11:07 AM
Totally destroyed turning only burl ever harvested due to inexperience so I am best qualified person here to give advice. Would try to turn a hollow form vase with what you have there.
Looking at the picture would start cutting top showing the split cutting back until found good wood, and same with bottom. So can turn between center and mount in a chuck later.
I always start my bowls & hollow forms between center to remove bark before mounting in/on chuck or faceplate. Just gives me a better idea of what have to work with.
Good luck with it!
-- Bill
ormonddab
#6 posted 08-05-2015 05:55 PM
Thanks for all the suggestions so far. I will be at my home in NC next weekend where the burl is and plan to begin turning something with it.
Nice work DaveDelo on that vase. You and others have given me some direction by considering a hollow form.
I appreciate the help and look forward to see if anyone else has a thought.
Thanks,
Dave
View FancyShoes's profile
FancyShoes
550 posts in 1387 days
#7 posted 08-05-2015 06:53 PM
You can get a lot of pens out of that burl. Not sure what else to recommend.
View TheWeiss's profile
TheWeiss
50 posts in 1258 days
#8 posted 08-06-2015 06:06 PM
Whatever you do I want to see it! Best of luck!
View pmayer's profile
pmayer
1028 posts in 3088 days
#9 posted 08-06-2015 07:17 PM
I’d turn one big bowl.
