Stanley Bailey #4 -bought it about 1970 - should I keep it.....
Forum topic by Jim Bertelson posted 28 days ago 371 views 0 times favorited 18 replies Add to Favorites Watch
View Jim Bertelson's profile
Jim Bertelson
268 posts in 58 days
28 days ago
I have not used my plane for a long time, but I know, now that I am getting into the hobby end of woodworking, that I will use planes. It is a Stanley Bailey #4 circa 1970. I bought it new. It has a lot of dings and evidence of use.
I think that I should just buy a few very good planes, and not deal with the minutia of this aspect of the hobby. I am not into reclaiming planes, buying antiques, etc. Chisels and planes I would just like to throw some money at and be done with it. Learn to use them, sharpen them, etc. I do like to tinker with machines. Practical, when it comes to the planes and chisels. No strict budget.
Would you believe I owned just this one plane, for almost 40 years. Utilitarian stuff was me, but now I am starting woodworking as a hobby. Furniture, not big tables, maybe someday a chair, but I doubt it. Small stuff. But good wood….end table, book ends, clock, Arts and Crafts [ no choice, my wife’s choice ], etc.
So where does this plane fit in my universe? Should I put it into a corner of my shop, a momento, and forget it? Should I just sharpen it. Should I buy a new blade?
Thanks in advance for the info.
-- Jim, Anchorage Alaska
View CoolDavion's profile
CoolDavion
215 posts in 718 days
28 days ago
I’d say keep it /use it.
I’m in the process of learning to tune/use planes, I got a unknown “Made in the USA” plane from my uncle’s stuff that I had for a couple of years and decided to finally try it out. If nothing else you could learn/practice sharpening (if necessary) w/ the existing blade and get a new one if needed latter.
-- don't sweat the petty things and don't pet the sweaty things
Jim Bertelson
28 days ago
CoolDavion:
Sounds good, if I screw up the blade sharpening it, no big deal. I really have no fixed thoughts on the matter, but that sounds more than reasonable. Thanks.
View Bothus's profile
Bothus
225 posts in 70 days
28 days ago
Hi Jim,
I splurged and bought a Lie-Nielsen block plane even though I had a Stanley and another no name block plane. I have not regretted it.
When you have quality tools it makes want to go quality work. I know Lie-Nielsen is pricey and there are a lot of people who will tell you Lee Valley is just as good and they may be. I never tried one.
I had an opportunity to go to a roadshow by Lie-Nielsen a while back and they taught me how to sharpen my plane. I doubt if they will take their roadshow to Anchorage though, they aren’t even coming back to Los Angeles in 2010 according to there current schedule.
I still have the old planes but I never use them.
Having said all that, if it were me I’d keep it. But this I never get rid of anything.
Bothus
-- Professional kitchen designer, amature woodworker.
Jim Bertelson
28 days ago
Thanks Bothus,
You are reinforcing my feeling. Buy some good planes, keep the old one to practice with, as per CoolDavion, and be on my way.
View cmaeda's profile
cmaeda
192 posts in 448 days
28 days ago
Hi Jim, I would use the #4 so you know how to tune it and get it working really well. If you mess it up, its’ no big deal. It will also let you know a high quality plane when you use one.
Believe me, I have a bunch of old planes that I tuned and fettled. But when I bought my first lie-nielsen plane, I realized I had a long way to go before making my stanley planes work that well (but I eventually did get most of my old planes working really well).
View WayneC's profile (online now)
WayneC
5972 posts in 991 days
28 days ago
I would keep it and play around with it. Although I do think that Old = Good. Although, perhaps a bit older than 1970.
View stefang's profile
stefang
1646 posts in 228 days
28 days ago
Hi Jim, I also have a Stanley jack plane I bought around the same time. I tuned it up long ago and it is actually a
reasonably good plane. Some years ago I dropped in my then workshop which had a cement floor and a very large chunk of one side broke out. I still use it though, and it performs just as well as it always did. I think the most important things about using a handplane are tuning, and sharpening. There are a million references to both on the web if you don’t know how. The tuning is a little bit of work, but it only has to be done once. It is great to have a handplane for small work such as boards too short for the machine planer or for finish smoothing a surface which saves a lot of sanding time and mess.
-- Mike, American in Norway
View knotscott's profile
knotscott
522 posts in 269 days
28 days ago
Keep it…..40 years of history is too hard to replace, and it probably wouldn’t fetch much over $25 or $30. My favorite plane is my Grandfather’s Stanley 220…it’s a decent enough plane, but the fact that it was his is priceless.
Jim Bertelson
28 days ago
Thanks everyone,
Sounds like the consensus is keep it for learning and nostalgia, but you may want to get a good plane or two….........
View Rick Boyett's profile
Rick Boyett
43 posts in 106 days
28 days ago
I’d keep it. I have several very old Stanley’s that have fantastic performance. You just have to get them tuned up properly.
- make sure the sole of the plane is flat. If needed, flatten with wet sandpaper over a piece of glass.
- sharpen the iron properly.
- Set the cap iron properly (should be 1/32” or less from the edge of the blade.)
- Set the mouth opening properly (should be about 1/32” or less of an opening)
You’ll find that you can get shavings that are almost as good as those from a Veritas and Lie-Nielsen. The main difference with those planes are their higher quality materials, very tight tolerances, and adjustment systems. They are OUTSTANDING planes but IMHO you don’t need to spend a load of money on them to get high quality results.
View Don Newton's profile
Don Newton
530 posts in 512 days
28 days ago
Hey Jim….keep the Stanley. The No. 4 is a good versatile plane. I think it would be a good daily use plane. At least it’s always good to have a “beater” around for those boards that might be a little dirty or may have metal in them. A good block plane is a must and you should consider adding one.
As far as tuning…..ALL of my planes, currently around 20, are old Stanley/Baileys and I have never taken the time to tune any of them. All I do is clean, oil and sharpen them. I’ve never run across instructions in old woodworking guides to tune metal planes and think it is a modern issue. It’s kind of like the Starret square for woodworking….How accurate is accurate enough?
-- Don, Pittsburgh
View TheDane's profile
TheDane
197 posts in 556 days
28 days ago
The #4 is a ‘Smoothing Plane’, and unless there are problems with the casting or the tote or knob I would definitely keep it. Sharpen it, lap/flatten the sole, and it should give you many years of use.
As you get further along, you’ll discover that you need (or can make use of) additional planes. The #4 can be a good tool, but you’ll want to look for at least a block plane, and maybe a jointer or a fore plane. Lie-Nielsen and Veritas have excellent offerings, and some say the new Stanley planes are worth a look.
One thing I have found is I can improve the performance of an older plane (I have a #3 that iis 110+ years old) with new, high quality irons and chip breakers. I have a personal preference for blades from Hock Tools (http://www.hocktools.com). Hock is not cheap, but in my experience, you get what you pay for.
-- The only place success comes before work is in the dictionary. -- Vincent T. Lombardi
Jim Bertelson
27 days ago
Don, Rick, and TheDane,
Thanks for the advice. Amazing the skillset and experience here on LJ’s.
The old plane is in excellent shape, but I think I would replace the blade. Nice to see the castings that are crisp, with no plastic in sight. Might refinish the tote and knob, but except for some chips in the finish, they are perfect. Could be the goto plane for daily use. I will lap/flatten the sole just for the experience. Then have to buy a plane or two, or more, I understand. That’s part of the hobby too….......................spending money (-:
This is all thinking ahead, from a DIY utilitarian worker. But working with solid hardwood is a different deal, I know. So I am setting up for it. Plan ahead, get organized, gotta do tools, learn stuff, do some practice projects…...........
Thanks.
Rick Boyett
26 days ago
One thing I forgot when setting up that plane.
Take the top of the blade (side that the cap iron rests on) and flatten the top quarter on the cutting edge end. The purpose is to make sure that the cap iron has NO gaps between its leading edge and the top of the blade. You will also want to flatten the leading edge of the cap iron for the same purpose..
Works wonders on the plane’s performance.
View SteveC3606's profile
SteveC3606
8 posts in 37 days
26 days ago
I’d Keep it. Even if you don’t use it it will be worth more in the future than it is today. But in the meantime you’ll have an inexpensive plane to use while you decide if y ou want to go for a more expensive one.
-- Stevec3606
View RexMcKinnon's profile
RexMcKinnon
676 posts in 89 days
26 days ago
Keep it. Good for rough work on wood that might have nails/screws that could damage your good planes. Sometimes rough lumber even has dirt and little rocks in it. Be a shame to use a high end plane on that stuff.
-- If all you have is a hammer, everything looks like a nail!
Jim Bertelson
25 days ago
Rick, Steve, Rex:
Thanks for the advice. It doesn’t sound like I would have to do a lot to make the plane very serviceable, although it works now. But not to my current standards. And it sounds worth doing for the practice and to get a plane for regular, “let’s not worry about dinging it” stuff. It has suffered from some lack of experience, although I had a little knowledge. It has only dings on the wood, the metal is perfect. I’ll have to look at the blade carefully, needs sharpening, but I never did anything worse than hand sharpen it on a stone. At worst, I buy a new blade.
Great input guys…........
25792 posts in 1294 days
25 days ago
I go for keep and tune it up and use it. You could put in a higher quality blade and probably get a great user.
