Dowelling bed frame 2x stock
Forum topic by Eros posted 08-04-2015 07:05 PM 738 views 0 times favorited 3 replies Add to Favorites Watch
View Eros's profile
Eros
1 post in 903 days
08-04-2015 07:05 PM
I am going to ca next month to build my daughter a king size bed using 2x redwood stock. I read Taunton new book on pocket hole joinery and I like their bed plans. The bed frame is essentially 2×6 joined to 2×6 thin edge to thin edge.
Author recommends dowelling to position boards….strongly recommends either jessum or dowel max jig….coupled with pocket hole joinery.
I do not want to spend $120 for jessum one time project.will the lee valley or woodcraft self centering jig do the job?
Suggestion appreciated. I will use knockdown metal hardware for joining bed rails to headboard and footboard
Thanks
3 replies so far
View jdh122's profile
jdh122
969 posts in 2694 days
#1 posted 08-04-2015 09:37 PM
I’ve had good success with shop-made dowel jigs. Just a block of wood with a hole drilled through it vertically (a drill press works best) and lines marked along the sides.
But I’m sure that either the LV or the Woodcraft ones will work fine for the job.
I’d add glue to that joint if I were you – since it’s a long-grain joint it’ll be very strong.
-- Jeremy, in the Acadian forests
View rwe2156's profile
rwe2156
2756 posts in 1357 days
#2 posted 08-04-2015 09:52 PM
2 screws, 1 dowel and plugs?
View MOONKNIGHT's profile
MOONKNIGHT
5 posts in 903 days
#3 posted 08-04-2015 10:28 PM
