woodchuck Irt Legacy Ornamental mill
Forum topic by a1Jim posted 29 days ago 424 views 0 times favorited 9 replies Add to Favorites Watch
16776 posts in 472 days
29 days ago
Topic tags/keywords: lathe
Here’s a hard to find item I thought someone might be looking for. Seems cheep enough
Woodchuck IRT-33 Legacy Ornamental Mill Milling
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=160372593527&ssPageName=ADME:B:SS:US:1123
View Mike's profile
Mike
140 posts in 277 days
29 days ago
Interesting….. You just never know what you are going to come across. Thanks for sharing.
-- Mike, VT
25801 posts in 1295 days
29 days ago
I’ve got a buddy that has a Legacy Mill This one looks really old.
29 days ago
It does look like an oldie . It says it was the first model . But I think the the new models go over $3000.
View Andrew's profile
Andrew
100 posts in 93 days
29 days ago
Looks like a cool machine, thanks for sharing.
-- As the Saw Turns
View papadan's profile
papadan
459 posts in 263 days
29 days ago
LJ Don butler has a legacy and does fantastic work with it.
-- Dan-- Info for all @ http://www.hoistman.com
View jack1's profile
jack1
381 posts in 922 days
28 days ago
I could use another anchor, two are useful if you want to stay a beam of the wind as you fish…
That’s about what I’d do with it since I have no knowledge of what it does or how it works!
-- jack -- measure once, curse twice!
View DaveR's profile
DaveR
1526 posts in 615 days
28 days ago
Yep, that one is very old by Legacy standards. I had a 1000EX for a number of years but sold it a bout 3 years ago. Don seems to have much better results from his mill than I ever got from mine.
-- Until you spread your wings, you'll have no idea how far you can walk.
View RealtorJim's profile
RealtorJim
3 posts in 7 days
7 days ago
Ironically, I am the one who purchased this item. It was a fluke I ran across this site while doing research on it. While it is not the ornamental mill as described (that would be the latter Woodchuck MA), it is a Woodchuck IRT-33. Although the 33 referred to the original length in inches, this one has 8’ foot rails. They do appear to be OEM. So in essence, it is an 8’ long fixed, indexable router table that is adjustable head and tail to create tapers. There were some gears and parts that came with it, but they appear to be for a Woodchuck MA. Maybe someone thought they could convert this into an ornamental mill. Possible, but the cost factor would be high unless a reasonably priced 8’ long feedscrew could be obtained. I had to straighted the mid brackets upon getting (appears someone might have stood on it). Make no mistake though, this is of heavy duty construction. The table rails are channeled steel, the adjustable table guides are steel, and the indexing plates are heavy gauge aluminum. I just finished building a base for it, and hope to have it attached and operational soon!
-- "If you can't find it, build it. If you can't build it, then you must need some more tools."
RealtorJim
3 posts in 7 days
7 days ago
I guess I should clarify what I meant when I stated “not the ornamental mill as described” in my last post. While it is an ornamental mill, it cannot make spiral cuts (what many, including myself, think of with the term ornamental milling). But fixed positioning ornamentation should be a piece of cake.
