Have a potential client that is interested in an outdoor extendable table made of light colored wood. What do you think of using maple outdoors with an epoxy finish to protect it? Does anyone know of aluminum table extensions that can be used outdoors?
I don't know much about epoxy finishes but I thought that if you can't find aluminum extensions you may be able to make some out of teak as it has natural oils in the wood. Just a thought. Good Luck sounds like a interesting build.
White oak is usually recommended for outdoor use if you want a light colour. Epoxy should work but it would cost a lot to cover the entire table, and it isn't UV resistant so you still need a spar varnish on top of the epoxy for it to last.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
