| Forum topic by RetiredCoastie | posted 1306 days ago | 3203 views | 0 times favorited | 11 replies | ![]() |
1306 days ago |
I’m building some boxes using finger joints but my dado set doesn’t cut clean bottoms in the joints and I’m contemplating buying this set. I don’t have a router table yet so a router is out of the question at this time. Have any of you folks used this finger joint set? What is your opinion? -- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops |
11 replies so far
#1 posted 1306 days ago |
I would check on there return policy and if they let you return if you don’t like it, then give it a try. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#2 posted 1306 days ago |
Jim thanks for the fast reply. I am also looking at a stacked dado set. I’m weighing the pros and cons. My stacked set works for some joints but not for decorative joints with out sanding and that’s time consuming. Can you recommend a stacked set? -- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops |
#3 posted 1306 days ago |
Hey RC http://lumberjocks.com/topics/11053#reply-113493 -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#4 posted 1306 days ago |
I have the Freud S508 dado set, it cuts very clean finger joints. It’s a bit on the pricey side at $200. Refer to the link Jim posted above for more info on that and the cheaper 208 set. I would recommend getting a stacked dado set like Jim says…you’ll use it for a lot more than finger joints. Oshlun also sells a stacked set for a little bit more than the finger joint set that seems to be getting good reviews: http://www.rockler.com/product.cfm?page=17335 |
#5 posted 1306 days ago |
i just saw the listing for like $40 i figure if it makes flat bottom cuts its a keeper i have the freud one like it also their dado blade and they give me flat bottom cuts but i bought a cheap delta one and this gives weard allmost like a ‘M’ shape cut so it just sits on the shelf watches me use all the other blades i have through the pkg. -- Ike, Big Daddies Woodshop, http://www.icombadaniels@yahoo.com |
#6 posted 1306 days ago |
Don’t go the easy way. Make boxes the right way, with a good old coping saw. |
#7 posted 1306 days ago |
I actually just got that set a couple days ago and loaded it up. The first cuts were clean with a really nice flat bottom. If they continue to perform like this, this will be the best $50 I’ve spent. The only issue I have with them is that because of the way the blades are set, the center of the 3/8 cut is a bit to the right of my dado blades. That means I’ll need to build another box joint jig for my table saw. Still, so far things look good. -- Working at Woodworking http://www.VillageLaneFurniture.com |
#8 posted 1306 days ago |
For the price you are talking about you could build a good router table ( if you have the router). Very simple designs all over this site. Here is mine. Made a box joint jig to go with it also. Works great. Used a scrap piece of Corian for the top and ply legs. Total cost $2.00 screws. Just a thought. Scrappy -- Scrap Wood's the best...the projects are smaller, and so is the mess! |
#9 posted 1306 days ago |
Thanks for all the input you folks provided, it was very helpful. After visiting many websites and the rockler store, I wound up buying the Freud box joint set. I would have liked to have gone with the Freud stacked dado set for all the reasons you guys stated but at this time I couldn’t afford the price and rockler gave me a good deal on the Box joint set. Now I’m just troubleshooting my jig and getting it tuned. The test cuts I made are great. They are square and flat. Just a matter of getting the pin spacing correct. Thanks again guys! -- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops |
#10 posted 1305 days ago |
I think that if you read the Rockler reviews , all 5 stars, you will see that other customers like it. As far as returns Rockler has super customer service IMHO. -- Only the Shadow knows.................... |
#11 posted 1305 days ago |
I go with Jim’s recommendation on the Freud blades … they cost a bit more, but I have found the quality to be top drawer. I actually have both a dado set and a box-joint cutter set from Freud. -- Gerry -- "I don't plan to ever really grow up ... I'm just going to learn how to act in public!" |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3552 |
15797 |
Hand Tools
2038 |
Jigs & Fixtures
495 |
Wood & Lumber
2842 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
