French cleat for floating desk
Forum topic by CudaDude posted 08-03-2015 10:10 PM 2395 views 0 times favorited 4 replies Add to Favorites Watch
View CudaDude's profile
179 posts in 2238 days
08-03-2015 10:10 PM
I’m planning on building something very similar to this for the kids rooms. In considering mounting options, I keep going back to a french cleat along the top and a ledger board under the desk top. My plan so far is to use 3/4 ” ply for everything including the desk top and edge band the desk top with 1 1/2” poplar to make it look thicker. The length of the desk is going to allow me to catch three wall studs. I’m guessing the desk will weigh around 60-65 lbs. I’m skeptical of the french cleat holding the weight with the leverage of someone potentially leaning on the front of the desk. Can you recommend some other methods of hanging this that will conceal the fasteners? Or, do you think the cleat will hold? Thanks in advance.
-- Gary
View JoeinGa's profile
7733 posts in 1937 days
#1 posted 08-03-2015 10:21 PM
How ‘bout TWO French cleats? One at the top and one at the bottom.
View AlaskaGuy's profile
3970 posts in 2239 days
#2 posted 08-03-2015 11:14 PM
A French cleat hitting 3 studs will be more than enough.
These will hold 200 lbs and that’s just wall dogs into sheet rock.
You could but one on the bottom just to keep someone from pulling the bottom away from the wall.
View Redoak49's profile
3125 posts in 1919 days
#3 posted 08-03-2015 11:44 PM
I have used 3/4” plywood French cleats into studs and strong fastening into a cabinet. It will hold a lot more than I can ever put in it. I think it is one of the strongest methods.
View bondogaposis's profile
4630 posts in 2281 days
#4 posted 08-19-2015 05:48 PM
I have to agree with everyone in that if you attach your cleat to three studs w/ adequately long screws, that will be more than enough strength for this desk.
-- Bondo Gaposis
