| Forum topic by woodman71 | posted 29 days ago | 336 views | 0 times favorited | 6 replies | ![]() |
29 days ago |
I’m building a table out woodsmith magazine from august 09 the plans call for the table rails to be 1 1/2 thick 2 1/2 wide the problem I had is when I bevel the front faces the plans call for 10 degrees bevel that ends 1/2 inch for the top and distance between lower part of the blade and fence is 1 1/8 inch and plan give no height for blade the problem i was having is that when I bevel the scrap wood it was to high about 1/4 inch for top lower blade and I would have groove for blade cutting in to wood I check see if my blade was really at 10 degrees did this like four times it was right I could not bevel the wood like the plans call for I had to tip blade to 12 degrees to keep what the plans call for I was wondering if someone can tell me is there some rule to beveling edges like a guide line to follow our was I do some wrong from what I see I was not and I could not get it to work used a lot scrap wood before I tip the blade to 12 degrees and it work right away it very frustrating for me because I follow what they said and it didn’t work and my first thought was I was doing some thing wrong and I would not stop until I got it right but I must have spent hour maybe hour half and I could not do it with blade at 10 degrees I’m still think I did something wrong but once I tip the blade to 12 degrees it work out 1/2 for top and 1 1/8 at bottom the reason I’m ask you guys is because later in plan you have to make legs to fit that bevel now instead 10 degrees on the legs I’m going to have to go 12 degree and I hoping that I don’t have problems and advice that you guys can give me I will be very thankful thanks |
