| Forum topic by pashley | posted 33 days ago | 489 views | 1 time favorited | 17 replies | ![]() |
33 days ago |
Topic tags/keywords: wood putty Anyone know how to make a custom “wood putty” to get an exact match on color? I have a tile inset into a wood piece, and I need “grout” – the wood putty – to fill in the gap. |
33 days ago |
I use to use plumbers putty and the acrylic art oil colors in tubes. I learned this when I first started building cabinets in the mid 70’s. If the putty was too oily and sticky after mixing we added a little corn starch to make it more easy to use. Really worked well as we finished all our cabinets and then filled the nail holes. It blended so well you could not even find the nail whole most of the time without really straining the eyes to find them. -- Jerry--A man can never have enough tools or clamps |
33 days ago |
Sounds like a cool trick Jerry. -- Jim from Heirloom Woodshop Southern Oregon |
33 days ago |
I’ll keep this in mind cabinetmaster this sound like a real winner in my book. I have plenty of your recite on hand, must raid the pantry for corn starch. Thanks Blackcherry |
33 days ago |
i run a peice of the wood i want to match thru the drum sander without the dust collector. gather up the fine dust and mix it with titebond 3 and fill nail holes. matchs pretty close. -- jerryw-wva. |
32 days ago |
I agree with jerryw. The dust of the board your matching and some wood glue. BTKS |
32 days ago |
Wood glue and sawdust is a winner…..have used it to repair stuff and works great. -- Measure once cut twice....oh wait....ooops. |
32 days ago |
Hi Pashley I use comercial wood fillers that are water based. I apply the filler once the 1st coat of the selected finish has dried. then i can mix a filler to match the exact color of the finished project and will not bleed into surrounding area. I wipe off excess filler with damp cloth and the only filler left is in the spot i want it in. -- Always give it your best shot |
32 days ago |
LIEBERON wood waxes for me.. You can match any color under the sun…Wood that is… lieberon.co.nz (Wax filler stix) Kiwi product. Best thing since toffee apples. For me anyway. -- "Even small steps makes a distance." (Shawn Phillips, musician) |
32 days ago |
I agree with the sawdust and wood glue on a project that has not been finished yet. But my first response is still the best if you have already finished the job and need to fill some spots missed before finishing. -- Jerry--A man can never have enough tools or clamps |
32 days ago |
Sorry that was a miss quote www.liberon.co.nz Oh I forgot…. The best is that when you finnish with a job and you see a split/hole/whatever you go back with the wax filler and fill. No real need to re-finnish. (Most jobs) Brilliant ! You try—you like—you smile. -- "Even small steps makes a distance." (Shawn Phillips, musician) |
32 days ago |
I agree with notottoman, wax fill sticks. You can get liberon, mohawk, and I’m sure various other brands. They normally have a wide selection of colors, but can be mixed. simply rub it in, then wipe off the excess with a cloth. -- ~ Inspiring those who inspire me ~ |
32 days ago |
Vincent Nocito posted this on my Limbert Lamp Table blog: “I sometimes make my own putty with sawdust and stainable wood glue (like Elmers Probond). If you are hiding small nail holes, it works pretty good. Mix sawdust from the boards from your project about 1:1 with glue. Knead to a dough like consistency and fill. Doesn’t look great if you are trying to fill large gaps.” -- You can't control the wind, but you can trim your sails |
31 days ago |
Ok—here’s one for all of you. Years ago me and my wife worked with a guy in Oklahoma building resophonic, or DoBro guitars. I built the guitars, my wife did all the inlay work on them(Mother of Pearl, Aboloney).
Our top of the line guitars were black walnut, and the lower line was mahoganey. I used Hershey’s Coco and expoxy mixed together to fill the pores. I also used walnut dust and glue, but the Coco worked the best. -- Remember--- one good turn-- gets most of the blanket!!!! |
30 days ago |
A trick I use to fill small cracks and small holes. -- John Stoler Apple Creek Ohio |
30 days ago |
Here’s another -- "Even small steps makes a distance." (Shawn Phillips, musician) |
30 days ago |
I have had mixed results titebond and sawdust. because it does not take stains well. I have had better luck with Minwax waterbased putty mixed with dry pigments or WB stain mixed in. even if it is not exact it will take additional stain pretty well. I have also used 5-min epoxy… mix sawdust and pigment into ONE part until it is even and thick, then mix in the 2nd part, this will give you a lot more working time. -- Dane, Fairview Pk, OH. The large print giveth and the small print taketh away... |
30 days ago |
I’ve use my wife’s water color tubes to mix with epoxy and sawdust (it doesn’t take much), or ZARs neutral wood patch mixed with sawdust. I try to have a finish coat on first before any patching. I didn’t have much success using glues and sawdust. Sometimes a little shoe polish worked just fine. -- Al H. - small shop, small projects... |
| Forum | Topics |
Woodworking Skill Share
2917 |
3944 |
256 |
949 |
224 |
Woodworking Trade & Swap
619 |
Coffee Lounge
2389 |
LumberJocks.com Site Feedback
524 |
