Craftsman 113 series won't stay square with height adjustment
Forum topic by jtm posted 08-03-2015 01:57 AM 742 views 0 times favorited 5 replies Add to Favorites Watch
View jtm's profile
jtm
230 posts in 1606 days
08-03-2015 01:57 AM
Hi all,
I have a Craftsman 113 series table saw. Today, I was squaring up (so I thought) some 1.75” table legs.
However, none of the cuts were square. When I checked my blade, it was off a little bit.
I began to raise it to its full height to adjust for square. However, as I began raising it, I noticed that the blade angle changed back and forth as I adjusted the height. (I think this is a different issue from the Ridgid/Grizzly table saws of late, since my blade basically wobbles in and out of square with adjustment).
Any thoughts or ideas?
Thanks in advance
5 replies so far
View TheFridge's profile
TheFridge
9255 posts in 1455 days
#1 posted 08-03-2015 02:01 AM
Is this happening with the angle lock tightened?
View jtm's profile
jtm
#2 posted 08-03-2015 06:35 AM
yes.
That was the first thing I checked
- TheFridge
View MrUnix's profile
MrUnix
6612 posts in 2168 days
#3 posted 08-03-2015 06:42 AM
Without knowing the exact model, it’s hard to determine what you got (there were a bunch of different saws made by Emerson sold by Sears)... But it sounds to me like a loose bushing (or less likely, a loose gear), although it might be as simple as a couple loose bolts or nuts. Most bushings are held in place with a set screw that can loosen up over time and lack of maintenance. Grab a parts diagram and check where they might be, or just crawl under the saw and take a look around (they aren’t all that complicated!). Make sure everything is tight – bushings, nuts, bolts, any gizmos or widgets, tighten what isn’t and give the moving bits a shot of dry lube or whatever your preferred slick stuff is.
View jtm's profile
jtm
#4 posted 08-04-2015 02:42 AM
It’s the much maligned Flex Drive.
Without knowing the exact model, it s hard to determine what you got (there were a bunch of different saws made by Emerson sold by Sears)... But it sounds to me like a loose bushing (or less likely, a loose gear), although it might be as simple as a couple loose bolts or nuts. Most bushings are held in place with a set screw that can loosen up over time and lack of maintenance. Grab a parts diagram and check where they might be, or just crawl under the saw and take a look around (they aren t all that complicated!). Make sure everything is tight – bushings, nuts, bolts, any gizmos or widgets, tighten what isn t and give the moving bits a shot of dry lube or whatever your preferred slick stuff is.
- MrUnix
View RogerM's profile
RogerM
792 posts in 2368 days
#5 posted 08-04-2015 05:29 PM
Pretty typical of a Craftsman product.
-- Roger M, Aiken, SC
