Bridle Joint Questions
« back to Joinery forum
Forum topic by Dave Owen posted 08-02-2015 04:41 PM 695 views 0 times favorited 1 reply Add to Favorites Watch
View Dave Owen's profile
Dave Owen
254 posts in 3038 days
08-02-2015 04:41 PM
Topic tags/keywords: chair repair bridle joint broken chair gluing
I’m repairing a spindle back chair with a bentwood outer rail. The spindles are ok, but when the chair failed, the tenons on the bottoms of the bentwood rail that fit into mortises (drilled holes) in the chair seat were both broken off. While there might be better ways to make the repair, I’ve decided to duplicate the tenons and short segments of the straight lower ends of the rails. To join the new parts to the old, I’m using what I can only describe as ‘in-line’ bridle joints. I’m almost ready to reassemble, and I know I’ll need to maintain excellent strength in those joints, so I’m looking for suggestions as how to best insure that assembly doesn’t remove enough glue to weaken the finished joint. Thanks for any suggestions.
-- Dave O.
1 reply so far
View waho6o9's profile
waho6o9
8162 posts in 2541 days
#1 posted 08-02-2015 04:44 PM
slow setting epoxy and good luck Dave!
