1/2" hole will not fit 1/2" wood dowel
Forum topic by EdsCustomWoodCrafts posted 07-31-2015 06:54 PM 2879 views 0 times favorited 16 replies Add to Favorites Watch
View EdsCustomWoodCrafts's profile
EdsCustomWoodCrafts
859 posts in 1516 days
07-31-2015 06:54 PM
I’m probably going to get a lot of grief over the post, but I’m out of options… Why don’t they fit and how do I get them to fit… Also the dowels need to move into and out of the holes easily otherwise I’d just hammer them in.
The project I’m working on is an adjustable height workhorse and the adjustable tier of the workhorse has several different holes to adjust the height of this jig of sorts. Before I went to the actual horse and drilled my holes I decided to do a test run and they don’t fit…
What to do!!!!!!
Should I just use a 1/2” drill bit and see if I can widen the the hole even by a 1/16th or more
-- Thanks Ed “A bad day woodworking is better than a good day working. ~Author unknown”
16 replies so far
View waho6o9's profile
waho6o9
8478 posts in 2750 days
#1 posted 07-31-2015 06:56 PM
Sand paper the dowels and use wax :)
View SirIrb's profile
SirIrb
1239 posts in 1403 days
#2 posted 07-31-2015 06:57 PM
Dowels are not as accurate as a bit may drill. I would put calipers on the hole and the dowel and see how far off they (the dowel, I bet) is. Id bump the hole up 1/64th. But after you measure the Dowel youll know where you should go.
View mahdee's profile
mahdee
4006 posts in 1940 days
#3 posted 07-31-2015 06:59 PM
Two options:
1- see if you can find a metric dowel
2- use a brass dowel
Third one would be to hammer the existing dowels through a piece of hardwood about 1/2 thick with the same drill. If the dowels are store bought, they are more likely made of soft wood and will squeeze in once travelling through the hole. Some wax afterwards should make the travelling easier.
-- earthartandfoods.com
View TheFridge's profile
TheFridge
10499 posts in 1659 days
#4 posted 07-31-2015 07:07 PM
Chuck the dowel in a drill and sand it. A block plane works too.
View jmartel's profile
jmartel
8193 posts in 2323 days
#5 posted 07-31-2015 07:13 PM
- TheFridge
This is what I was going to say. I’ve done both successfully before. Store bought dowels are rarely exactly the size that they list. In the future, it’s a good idea to bring a piece of scrap with a hole drilled in it so you can test out the dowels and find one that fits.
EdsCustomWoodCrafts
#6 posted 07-31-2015 07:17 PM
- TheFridge
This option sounds like it would work I’ve got a drill press and excuse to use it … Thanks everyone for the ideas
View HokieKen's profile
HokieKen
6594 posts in 1311 days
#7 posted 07-31-2015 07:27 PM
Sanding the dowels will certainly work. You can also go back with a 33/64” or 13mm drill bit and ream the holes out with it.
-- Kenny, SW VA, Go Hokies!!!
View jdh122's profile
jdh122
1042 posts in 2990 days
#8 posted 07-31-2015 07:37 PM
As others have said, dowels are not always very accurate when made commercially. But then again, it’s summertime and so the most humid time of year along the NA east coast, so the dowels may simply have swelled a bit. Either way, the solutions mentioned will solve the problem.
-- Jeremy, in the Acadian forests
waho6o9
#9 posted 07-31-2015 07:53 PM
Drill a hole in some steel about 1/64th under size and persuade
the dowels to behave.
View Richard's profile
Richard
1922 posts in 2863 days
#10 posted 07-31-2015 08:25 PM
Two options:
- mrjinx007
Most dowels I find in the big Box stores are actually Metric even though they say 1/2” or 3/4”.
And as Steve Ramsey say’s ” If you hand sand a Dowel , Don’t let anybody see you unless you wan to get some Crude Remarks” :)
View Redoak49's profile
Redoak49
3595 posts in 2161 days
#11 posted 07-31-2015 10:43 PM
It is my belief that almost all dowels are neither the exact size or round. I expect to have to size them with sand paper.
Secondly, drilling a 1/2” hole in different woods will result in holes of different sizes. Drilling in a 2×4, will give a rough hole. You can roll up some sand paper and run it through the hole to smooth it out. Between smoothing the hole and sizing the dowel should fix things.
View BurlyBob's profile
BurlyBob
5934 posts in 2438 days
#12 posted 08-01-2015 12:35 AM
What “The Fridge” said.
View jerryminer's profile
jerryminer
944 posts in 1614 days
#13 posted 08-01-2015 04:54 AM
Don’t know if this will work for your application, but I have had success with cutting a slot in the dowel with a bandsaw—a little less than the depth of penetration I want. this makes a somewhat undersized, but “spring-loaded” dowel—-a lot like the “Tinker Toys” you may (or not) remember.
Richard
#14 posted 08-04-2015 07:43 PM
Don t know if this will work for your application, but I have had success with cutting a slot in the dowel with a bandsaw—a little less than the depth of penetration I want. this makes a somewhat undersized, but “spring-loaded” dowel—-a lot like the “Tinker Toys” you may (or not) remember.
- jerryminer
“Tinker Toys” I do remember them .
View esmthin's profile
esmthin
77 posts in 1354 days
#15 posted 08-05-2015 04:13 AM
And as Steve Ramsey say s ” If you hand sand a Dowel , Don t let anybody see you unless you wan to get some Crude Remarks” :)
Everyone’s favorite Steve Ramsey quote. :)
-- Ethan, https://instagram.com/ethan_woodworker/
