Looking for some advice for first bandsaw.
Forum topic by misterbig posted 07-31-2015 06:21 PM 858 views 0 times favorited 4 replies Add to Favorites Watch
View misterbig's profile
misterbig
46 posts in 1880 days
07-31-2015 06:21 PM
Here is a couple of used bandsaws for sale in my area that I am looking at.
These saws are all $600 and all seem to run good. The 490 general is oldest.
View HokieKen's profile
HokieKen
7130 posts in 1341 days
#1 posted 07-31-2015 07:34 PM
$600 is a bit steep for a bandsaw unless you’re going to be resawing. If you just want it for general work, you should be able to find a good 12-14” saw for under $200. If you’re going to be resawing logs or veneers, then you will likely need to spend that much. I’ll let others weigh in on the specific saws ‘cause I’m not familiar with any of them.
-- Kenny, SW VA, Go Hokies!!!
View PurpLev's profile
PurpLev
8547 posts in 3851 days
#2 posted 07-31-2015 08:04 PM
It really depends on what you plan on using it for:
  • general/intricate work = smaller bandsaws are better as they can take narrower blades (tighter curves)
  • resawing = larger bandsaws with larger height capacity.
once you figure out your intended use, it’s easier to find the best price/quality combo for your needs.
misterbig
#3 posted 07-31-2015 08:39 PM
New to wood working so all I can tell you is that it needs to be 110 v as I don’t have 220 in the shop.(garage). It also needs to be mobile as I need to be able to move out of the way so car can park inside.
Mainly cutting shapes, intricate work. Wood be nice to be able to re saw once and awhile.
M
View distrbd's profile
distrbd
2252 posts in 2649 days
#4 posted 07-31-2015 08:48 PM
First choice= General 490.
2= the last band saw (3rd) picture.
-- Ken from Ontario, Canada
