Grain orientation when laminating 2 different woods...
Forum topic by ghazard posted 37 days ago 183 views 0 times favorited 3 replies Add to Favorites Watch
View ghazard's profile
ghazard
145 posts in 408 days
37 days ago
I am planning some reversable coasters. Two woods, laminated together with identical depressions cut on both sides so you can rest a glass on either side. Should the 2 woods be glued with grain in the same direction or perpendicular to each other?
Thanks!
Greg
-- If, in your life, you attain the means to help; you incur the responsibility to act.
View MedicKen's profile
MedicKen
485 posts in 361 days
37 days ago
My feeling on this is I dont really think it will matter if you are concerned about movement.They will be small and wont move a lot. I think for strength, and the fact you will be removing material from both sides, I would set the grain perpendicular. With material removed and the coaster is dropped it may break if the grain is parallel
17119 posts in 476 days
36 days ago
I agree with medicKen you won’t have enough wood movement to worry about.
ghazard
35 days ago
OK thanks! That will be my plan.
Greg
