| Forum topic by andy_P | posted 33 days ago | 243 views | 0 times favorited | 7 replies | ![]() |
33 days ago |
I do a lot of work where I need to put a trim around a base or edge a picture frame to hide end grain and also for design purposes. No nails or screws are used; just glue. I have a lot of problem with the trim piece wanting to slide out of square as I apply pressure to the clamp. Most times I end up pulling the joint apart and trying again before the glue gets beyond the point of no return. Has anyone else experienced the same problem or found a cure? -- Wood is a gift from God/Nature that maintains its beauty forever via the hand of a woodworker. |
