First trip to a saw mill
Forum topic by jeffswildwood posted 07-31-2015 12:31 PM 1518 views 0 times favorited 20 replies Add to Favorites Watch
View jeffswildwood's profile
jeffswildwood
3666 posts in 2211 days
07-31-2015 12:31 PM
Topic tags/keywords: saw mill trip
I made my first trip to a saw mill yesterday. Quite interesting! I went to see the cost of cutting some silver maple trees that had fallen in my yard into boards. Cost, $45,00 per hour. Does this sound about right? I told him it won’t be a lot and he said he gets done rather quickly.
While there he showed me his “personal” pieces of wood. Beautiful spalted lumber, walnut that is going to be a mantle, oak, cherry, maple, the list goes on. At this point I thought he would ask me to leave because I was drooling on his lumber! But no….
Before I left he gave me a beautiful streaked piece of poplar, four very dark pieces of ceder, and two slabs of cherry! All 4/4 and beautiful. A few flaws but easy to work around.
I have a friend that said he would haul the wood for me. I may make a deal, “cut all you can in one hour and trade the rest for some already processed wood. (loving that cherry).
Wonderful day and I did learn a lot about wood processing. The guy was a joy to talk to, taking time to explain things to me and show me his stock that I am sure I could purchase in the future.
-- We all make mistakes, the trick is to fix it in a way that says "I meant to do that".
20 replies so far
View CB_Cohick's profile
CB_Cohick
487 posts in 1485 days
#1 posted 07-31-2015 12:37 PM
That sounds like a good relationship to cultivate.
-- Chris - Would work, but I'm too busy reading about woodwork.
View JayT's profile
JayT
6002 posts in 2445 days
#2 posted 07-31-2015 12:40 PM
$45/hour sounds like a pretty good deal to me. The two sawyers I buy from would both charge more than that and I think they are very reasonable. Keep in mind that pretty much every yard tree has metal in it. If the sawyer hits some metal and trashes a blade, you will be expected to pay for that blade, in addition to the hourly rate.
You can try to barter for doing the job for a portion of the wood—some sawyers will work on a 50/50 split, or similar. They cut all the lumber and keep half and you get half. The only potential problem I see is that silver maple doesn’t have a lot of commercial value, so he may not want to do that. All you can do is ask and see what he says.
At the very least, sounds like you made a new contact as a source for lumber. That’s a good day all in itself.
View ChrisBarrett's profile
ChrisBarrett
99 posts in 1292 days
#3 posted 07-31-2015 01:06 PM
Why does yard tree have metal in it? Just from people nailing things to it over the years?
ChrisBarrett
#4 posted 07-31-2015 01:08 PM
Just for comparison, a local mill charges $125 an hour, with a 2 hour minimum.
View doubleDD's profile
doubleDD
8036 posts in 2277 days
#5 posted 07-31-2015 05:40 PM
I have no idea what the average cost should be but $45/hr sounds great to me. Sounds like you have some options you may deal for. Why not, go for it Jeff. You sure don’t get much in lumber for $100 these days.
View SirIrb's profile
SirIrb
1239 posts in 1465 days
#6 posted 07-31-2015 05:44 PM
Just a hint: find out his birthday and make sure he gets a Christmas card. This is the guy—as previously stated—you want a good relationship with.
View bonesbr549's profile
bonesbr549
1579 posts in 3301 days
#7 posted 07-31-2015 06:41 PM
I’m with the others good price. Now I say that assuming he knows what he’s doing. I’ve seen a couple bad ones that ruined some trees because they slapped and sliced. It does take some knowledge.
jeffswildwood
#8 posted 07-31-2015 08:07 PM
Looks like I hit a home run on this one! Not to mention it’s only a 15 minuet drive from my house. When the cutting is done, I’m going to check his prices for some of that spalted maple, walnut and cherry! Thanks guys for your opinion. Guess I may have to invest in a dewalt planer now. :)
View JayT's profile
JayT
#9 posted 07-31-2015 08:18 PM
- ChrisBarrett
That’s the most common issue—nails, fence staples & screws. BB’s & slingshot balls (I know not as much anymore, but 50 years ago when the tree was young, maybe), wire or chains that were grown over, and saw blades (hand saws) are also possible, if not probable. Heck, I know of hammer and hatchet heads that have been found inside trees when they’ve been cut and I’m sure there are instances of even weirder stuff.
View kaerlighedsbamsen's profile
kaerlighedsbamsen
1257 posts in 1948 days
#10 posted 07-31-2015 08:40 PM
Yes that sounds like your new, best friend!
Just a quriosity to add to JayT’s list above: Nearby my house there is a road tree that has a whole motorcycle grown into is a few meters up…
-- "Do or Do not. There is no try." - Yoda
jeffswildwood
#11 posted 07-31-2015 09:41 PM
We had a maple tree cut down by PSA next to the road in my yard that had a brick in it. Drove their crew crazy. I guess if I was a sawyer, I would have a metal detector close buy always! Don’t guess it would help with a brick though…..
View gfadvm's profile
gfadvm
14940 posts in 2924 days
#12 posted 08-01-2015 12:13 AM
Jeff, As a sawmill owner will say that $45/hr is a smoking bargain. Metal detectors don’t scan very deep and it is a PITA to scan after each cut. I would have him saw all of it because the part you don’t have sawn will be the part that has the curl/quilting/spalting in it (Murphy’s Law).
View putty's profile
putty
1236 posts in 1841 days
#13 posted 08-01-2015 12:31 AM
I was at a sawmill in northern Michigan, they had an old car starter they found in a tree!!!
-- Putty
View dhazelton's profile
dhazelton
2804 posts in 2531 days
#14 posted 08-01-2015 01:04 AM
I took a tree felling class at a small mill and ended up throwing some labor at them for having a couple of black walnuts sawed into boards. I also got a bunch of felled cherries and maples that were too twisted for them to bother milling (in their estimation, anyway). I even got to operate the mill myself on my walnuts. Small scale folks do it because they enjoy it and they know they aren’t gonna get rich. Good folks to know.
jeffswildwood
#15 posted 08-01-2015 12:20 PM
gfadvm, that would be my luck. I asked him if he liked silver maple and he said not his favorite, not enough grain action. Well see I guess.
