Attaching a sill invisbly
Forum topic by efsavage posted 38 days ago 179 views 0 times favorited 6 replies Add to Favorites Watch
Rockler
View efsavage's profile
efsavage
11 posts in 59 days
38 days ago
I’ve made a sill to go on top of two half walls, but I’m unsure how to attach them. Would be easy enough with some finish nails, but I don’t want any fasteners to be showing if possible. The only thing I can think of is to nail a cleat down and rout a channel for it, but I’m hoping there’s an easier option. There’s a stud below that joint compound. Any ideas?
View bentlyj's profile (online now)
bentlyj
797 posts in 370 days
38 days ago
Liquid Nail Adhesive,
View dbhost's profile
dbhost
629 posts in 132 days
38 days ago
Get to the stud, and Liquid Nails that thing down.
-- Trying to follow the example of the master.
View BeachedBones's profile
BeachedBones
187 posts in 302 days
38 days ago
X2 Definitely construction adhesive of some sort onto the stud. Don’t use much in case you ever want to pull it up again, a little goes a long way.
-- You know.... I think that old wood needs to be furniture.
17211 posts in 477 days
37 days ago
Silicone well work fine
View UnionLabel's profile
UnionLabel
153 posts in 100 days
36 days ago
http://farm3.static.flickr.com/2493/4040129464_02052e71ec_m.jpg
http://farm3.static.flickr.com/2771/4040129704_9f5ef6b420_m.jpg
http://farm4.static.flickr.com/3515/4040130004_f53b1b8399_m.jpg
I made this counter top about 3 yrs. ago. Had the same problem as you as to how to attach. Well, she is glued and screwed! The 3/4 poplar is screwed to the header in the knee wall then I pre-drilled holes upward in the line of the molding shown. When the top went on, I drove 11/4” screws upward through the poplar and into the counter top. The counter top was laid in a bed of liquid nails. The base molding was inverted with the wide part hiding the screw heads. No one knows exactly what was done except me and my son and now all the LJ’s and you.
-- Easy Peasy Lemon Squeezy-May all your dovetails fit tight and right the first time
View gagewestern's profile
gagewestern
157 posts in 250 days
36 days ago
if their is trim under it you could twonail through it then nail it to the wall
-- gagewestern
